Sterling Power Battery Maintainer
Discussion in 'The Beginner' started by Phil J., Jan 11, 2015.
  1. Phil J.
    Phil J.
    Dec 21, 2014
    111
    68
    Clay Cross, Derbyshire
    Hi,
    I have one of these fitted to my 2007 Autotrail Cheyenne 696. I have read through the blurb on the Road Pro website:
    https://www.roadpro.co.uk/retail/12...ts/sterling-power-battery-maintainer-1521.htm
    As far as I can see, when the leisure batteries are charges, the unit switches excess amps to the engine battery to keep it topped up.
    My question is - Why have I got it? As far as I am aware my Sargent EC325 already does this.
    Can anyone enlighten me?
    Thanks in anticipation.
    Phil
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,681
    17,298
    YO11 2BD
    Probably far more reliable than the sargent unit which appear to go wrong quite often according to various threads/post on fun.
    • Like Like x 1
  3. FULL TIMER
    FULL TIMER Read Only Funster
    May 31, 2012
    796
    712
    NORWICH
    From what I can make out your Sargent unit only charges whilst connected to the mains UNLESS you have a solar panel fitted in which case power from the built in solar regulator will charge both leisure and vehicle batteries, The Sterling unit will maintain your vehicle battery regardless as long as the leisure batteries are not flat. But also agree with pappajohn the Sterling is probably a lot more reliable, did you buy the van new if not may be someone had problems with the Sargent unit and opted to use the Sterling unit instead of repairing /replacing the Sargent unit.
  4. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,181
    14,952
    Leeds the one up North
    It only starts to transfer charge when the leisure batteries reach 13.3 volts.
    Very often extras are fitted with no knowledge of a vans existing electrics
  5. Phil J.
    Phil J.
    Dec 21, 2014
    111
    68
    Thats what I wondered. however, also sat at the side of it is a Roadpro 1000w inverter and I thought that they might be something to do with each other.
  6. Techno
    Jul 28, 2010
    14,181
    14,952
  7. Phil J.
    Phil J.
    Dec 21, 2014
    111
    68
    Cheers Andy,
    I've just watched the Youtube video and I'm clearer on it now. Re. our previous conversations I'm fitting the solar panel next week. Having the battery maintainer fitted means I can switch off the 12v on the control panel which stops the 0.3A drain and still charge the motive battery via the maintainer when the solar is charging. As you know when solar is connected to the EC325 it has to be switched on to maintain the motive battery at the same time as the leisure batteries when it's off only leisure batts are charged i.e. it won't discharge at 0.3A overnight.
    Thanks again.
    • Like Like x 1
  8. FULL TIMER
    May 31, 2012
    796
    712
    NORWICH
    Ah from the roadpro blurb I got the impression that it put a very small amount of current from the leisure battery into the vehicle battery as long as it wasn't flat as such.
  9. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    if you want to remove it I could well be interested.
  10. FULL TIMER
    May 31, 2012
    796
    712
    NORWICH
    now made clear after a visit to the Sterling website
  11. Techno
    Jul 28, 2010
    14,181
    14,952
    Yes the only item that will transfer charge under any conditions is a battery master "Vanbitz"
    Unfortunately the whole community now call every device a battery master WRONGLY! they are very different.
