Sterling Battery Maintainer
Discussion in 'Tech/Mech General' started by Dubiousp, Jul 15, 2013.
  1. Dubiousp
    Dubiousp Read Only Funster
    Jul 3, 2012
    233
    45
    Hampshire
  2. adds666
    adds666 Read Only Funster
    Jul 13, 2013
    8
    4
    Horsham
    Would this mean the Engine Battery is charged as well as the LB when the solar panel has done its thing on the LB and is floating?
    I found with our 90W panel in to an 85aH LB that it would be charged by 10am and floating. I combatted this by fitting a simple switch in parallel to the ignition control wire on the split charge relay. Then I could manually 'connect' the engine battery and starter battery when I was either on EHU or the Solar panel was floating after topping up the LB. Effectively then putting the power from the panel in to the starter and LB.
    My starter battery and LB were also wired in large 100A capable gauge wire so on those cold days when the starter battery couldn't turn over he old diesel engine I could flick the same switch and effectively 'jump start' the van using both starter and leisure battery.
    It should be noted that whenever I was to consume some energy I would disconnect the batteries using the same switch. Otherwise I'd run down the LB.
