hilldweller
i think its an easy diy project:thumb:
Says the man who restores write-off Seats in campsite carparks in Spain.
He just shot you down.
Only 35A available on tickover.
Standard system system gives you 80% charge.
So for that extra 20% you are going to add all this complexity and worse have your diesel running with a brick on the throttle pedal.
All you have to do it tell Nikki her hair looks wonderful if just gently rubbed with a towel. You might try running your kids off Fray Bentos pies instead of electricity.
I would rather arrive with my battery bank charged to 100% than 80%
Here are the sums.
3 x 125 Ah batteries = 375Ah available, but you should only look to use 50% before recharging so I have 187.5Ah to use.
Arrive with 80% charged batteries (125 / 80% = 100Ah) 3 x 100 = 300 Ah same rule of 50% discharge gives me 150Ah to use before recharge
So I gain 37.5Ah for nothing other than ensuring that my batteries are charged properly, irrespective of whether it is sunny, without resorting to a genny, a wind farm or sitting in the gloom or white light of having LED bulbs!
There are many charging systems that do similar things, in essence ensuring that the batteries are charged correctly. To do this the correct cable must be used to ensure that the voltage at the terminals is used to calculate the output voltage of the unit.
As for fuel consumption your driving a delivery van that has had a caravan grafted onto the back of it! so I doubt that fuel is a real question, and as for premature ageing? I personally don't care what happens to teh van in a few years time as I won't own it!
Regards
Eddie
I have just lost the will to live...
Hang in there Brother,
im going to ask about Traction Batteries, Solar Panels and then Aframes next :thumb:
Jeezus Haggenap, I may buy you the bloody Sterling Bleeding whatis, I am devoid of any enthuasm regards anything electrical,. 235v 1.2 amp at sea level at 10millibar, dependant on the amount of drink Chrisboyo has drunk on a wet Wednesday in Newport Pagnell multplied by the number of farts than can be generated from eating raw FB pies and organic hand baked baked beans.
Its a motorhome, if the batteries run out, and its dark, its time to sleep, if its light, time to get up.
Otherwise sell the motorhome, buy a donkey and move to Portugal and become JJ's assistant..
Motorhomes are meant to be mobile and thats it, I care not a blind cuss if someone is daft enough to spend £1000 on a wave inverter sinus whatsis.
Go to a campsite...
Easy!
Buy themc:thumb:
Waste of time for half the year, when you need themoh:
Illegal, we all know it but do it (Why don't A frame companies offer to pay our fines and legal bills)
I out of here before the flak
Bye
Eddie
How about positive pressurisation of your MH so when they try and inject gas into it it blows back in their faces.
Ok here goes...............
The Sterling B2B charger increases the useable capacity of your battery/batteries by charging them at a higher voltage (14.8V). The unit uses electrickery and witchcraft to amplify the alternator's output voltage of 14.4-14.5V. It just so happens this increased voltage creates more current and the battery charges faster as a result. A side effect of this increased charging current is less sulphation and longer battery life.
The reason that alternators do not charge at this increased voltage is because to do so will cause more battery gassing, water loss and more topping-up required by the battery owner. Obviously, this is not desireable in a modern motor vehicle and is the only downside of a Sterling setup. Having said that, we only need to top up once a year and our batteries are 3 years old with no sign of waining.
OK, now for that relay!
We use a 80Amp 5-pin relay to isolate the caravan electrics from the leisure battery bank whilst the engine is running. This relay is switched to open circuit by an ignition live.
When the engine runs, the leisure batteries are connected to the output of the B2B charger and NOTHING ELSE! When the ignition is switched off, the leisure battery is reconnected to the caravan electrics and it is business as usual!
The fridge, etc works in the normal way from the starter battery via the split charge relay and distribution panel.
As mentioned earlier, this relay is ESSENTIAL to prevent your B2B charger's input being connected to it's output via the existing split charge relay and the B2B charger being rendered useless!
Hope this explains things Paul!:thumb:
not realy missed muchoh:To save me going back over all the the posts in this thread, have I missed anything interesting?
To save me going back over all the posts in this thread, have I missed anything interesting?
Not yet Dane,, just waiting for Glen from John Cross to come and give me the final bit of Info
Bloody cheek! :Sad:
I thought one of my contributions was very witty... :Angry:
JJ :Cool:
PS Rofl1
