Step recess drain holes
Discussion in 'Motorhome Chat' started by DavidG58, Feb 14, 2016.
  1. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,025
    13,891
    Bolsover, Derbyshire
    following on from our Tsunami post on another thread (we have had a shower overflow for those that did not see that one)
    Came back from a walk and noticed small damp area on floor near door, lifted out mat in internal step area and found this
    not overly clear from here but about an inch of water stood in well
    fished around expecting to find blocked drain holes and found fitted plugs
    I was able to push them up fairly easily from underneath
    Question, would you refit them? (I have for now) but would it not be better for any water that does get in to get out again, there can surely only be a limited amount of water that can get in from the road through 2 x 8mm holes and it would go straight back out anyway
  2. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,380
    5,637
    Guisborough
    Leave them out for next time:LOL:
    Martin
    ps Hymer going up in my estimation putting drain holes where water might collect, whatever will they think of next.
    Martin
    • Like it Like it x 4
    • Funny Funny x 1
  3. Armytwowheels
    Armytwowheels Funster Life Member
    Aug 10, 2012
    4,173
    6,845
    Spain for the winter
    But David, the question should be - How did the water get there in the first place? Is your door seal OK?
    If you leave the plugs out you will/might get water coming in from road spray.
  4. davanne
    davanne Funster
    Mar 16, 2010
    1,411
    7,415
    Carmarthenshire
    They had a minor flood from the shower
  5. davanne
    davanne Funster
    Mar 16, 2010
    1,411
    7,415
    Carmarthenshire
  6. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,025
    13,891
    Keep up at the back Sandra :LOL: the tsunami came from our shower
    see below copied from our other thread
    'Moving on from there with more and more twists and turns, we got 1 mile from Mende and suddenly heard an almighty cascade of water, turned to see a mini tsunami heading forwards towards us
    Stopped at roadside and realised a towel had dropped in the shower, landed on the shower handle which lowers to turn on, you can guess the rest
    Actually you cant, to avoid issues with smells coming back from the grey tank we push down the shower plugs before travelling, now you can guess for yourselves
    It probably took a few minutes for the shower to fill unnoticed by us in the front, then a left hand bend sent most of the contents under the door on their way to us
    Thank goodness for under floor heating and access to water on the aire (y)(y), but at least we have a freshly cleaned floor :)'
    still not sure if road related wetness would come in though, but if plugs removed it would at least go out again (y):)
    • Funny Funny x 1
  7. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,025
    13,891
    quadruplicated post, that's a first for me :D
  8. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,025
    13,891
    edit triplicated post
    I blame @Jim not the wine we have consumed :D
  9. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,025
    13,891
    multiple post sorry, but good for Jims stats :)
  10. Armytwowheels
    Aug 10, 2012
    4,173
    6,845
  11. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,025
    13,891
    The bloody shower overflowed due to turning itself on in transit, that caused this issue
    My question was, would surface water get in through 8mm holes?
    I still don't know :LOL:
  12. Allanm
    Allanm Funster
    Jun 30, 2013
    3,186
    4,342
    Cotes d'armor, France
    It might do! We had water in the bottom of our step a while ago, at each side of the step well is a vent but water splashed up going through large puddles got through the vent into the footwell.
    The solution I used was to fix top hinged rubber flaps over the Outside of the vent as a sort of one way valve, so air can circulate but water can't get in. 18 months on and the well is still dry.
    I suppose you could leave the drain plugs out, but fix something loosely over the holes outside so water will drain out but not get splashed in.
    Then, your Hymer step will be as dry as my Autosleepers! :whistle:
    • Like it Like it x 2
    • Funny Funny x 1
  13. funflair
    Dec 11, 2013
    5,380
    5,637
    Guisborough
    Well if it does it can get back out again if you leave the bungs out(y)
    Martin
  14. SandraL
    SandraL Funster
    Jan 24, 2012
    300
    154
    Somerset
    We have same step arrangement in our hymer. Never had plugs in from when we had van, 15k miles later not had a problem. Our door is not next to a road wheel so does not get all spray from a wheel. Hope that helps.
  15. Wombles
    Wombles Funster
    Oct 28, 2013
    2,595
    1,890
    SW England
    Open drain holes in our Chausson step from new so presume that's how it is meant to be...
