Step not retracting
Discussion in 'Tech/Mech General' started by keith, Sep 15, 2014.
  1. keith
    keith Funster
    Aug 25, 2007
    3,301
    1,685
    Ecclefechan
    Our step retracts when starting the engine, or should do, but recently it hasn't been doing it. We can do it manually without any problem, but it refuses to go in when the engine starts as it has always done up to now.
    Any ideas? What makes it retract automatically?
  2. scotjimland
    Jul 25, 2007
    29,048
    25,741
    Suffolk
    It will have a 12v relay that operates when the ignition is turned on.. find that and replace it ..
    • Like it Like it x 1
  3. jamesvanbitz
    jamesvanbitz Funster
    Aug 29, 2013
    123
    123
    Taunton & East Sussex
    and it should be fused?? So something else to check?
  4. scotjimland
    Jul 25, 2007
    29,048
    25,741
    Suffolk
    yes, but it works manually so assume that's ok.. unless it has two feeds
  5. MikeD
    MikeD Funster
    Dec 21, 2011
    2,235
    1,934
    London
  6. jamesvanbitz
    Aug 29, 2013
    123
    123
    its just a trigger from the ignition that is fed as already mentioned to a relay. This may be fused to the step. It will have an independent power feed, and as you said this is all working ok.. its just not getting the signal from the front.. or sticky relay (as already suggested)....
  7. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,336
    8,073
    Norfolk
    Or it might be the limit switch on the step!
    They aren't best sealed and when fitted to a left facing door, the switch opening is facing forward to nicely catch road salt and any other contaminants!
    A spray of WD40 into the slot and a good working might sort it.
  8. scotjimland
    Jul 25, 2007
    29,048
    25,741
    Suffolk
    Circuit diagram..yours may not be exactly the same but gives some ideas what to check
    [​IMG]
  9. keith
    keith Funster
    Aug 25, 2007
    3,301
    1,685
    Ecclefechan
    Thanks for all the ideas.
    No Jon it all works OK, it's only the trigger from the engine that is faulty. The motor, step switch & limit switch are all working fine.
    It appears Jim that there is a relay somewhere that does the triggering, I just have to find it but from the 2 diagrams I have seen it appears to be a relay that may be used by another system as well.
    I now have 2 diagrams showing a relay from the fridge or the horn activating the step closure on start up, seems like some detective work for me tomorrow.
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,389
    18,079
    YO11 2BD
    I think these are merely descriptive terms......same item used on fridge or horn.
    Looking at Jims diagram it lists it as a horn relay but the horn isnt connected to it in any way and cant be as the horn would sound as the step motor is activated.
    It may be nothing more than a bog standard 30amp automotive relay
  11. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,336
    8,073
    Norfolk
    The limit switch only works on the auto retract circuit and not the manually switched side.
    The limit switch could still be the fault in this case.
    I wouldn't rule it out just yet!
  12. keith
    keith Funster
    Aug 25, 2007
    3,301
    1,685
    Ecclefechan
    Have a look at this one then John. http://www.motts.dsl.pipex.com/Omnistep.htm
    It states clearly there is a live feed from the fridge relay when the engine is running, as it would do if you wanted the fridge on 12V while running the engine.
  13. pappajohn
    Aug 26, 2007
    30,389
    18,079
    YO11 2BD
    Agreed, but the supply could be from any ignition switched circuit....and why would it say horn relay, which will possibly be far from the step relay
  14. Baycott
    Baycott Funster
    Nov 6, 2013
    6,510
    14,267
    East Sussex
    I had this problem on my AT Tracker ie step wouldn't retract automatically but was ok manually but also found that the fridge wouldn't work on 12v.
    I found the fridge relay under the bonnet beside the engine battery and there was a blown fuse in a block beside the relay.
    Hope this helps.
    John
  15. PP Bear
    PP Bear Funster Life Member
    Apr 5, 2013
    2,479
    7,688
    UK
    Had same thing happen to me, just before the alternator packed in, or at least the charge light came on and stayed on :)
    The main vehicle battery has lots of buzz bar fuses, as well as a number of other "inline" fuses too :)
    On inspection a small fuse had blown and simply needed replacing, so pinkies crossed yours is the same :)
