step issue
Discussion in 'Motorhome Chat' started by DavidG58, Jan 15, 2014.
  1. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,520
    12,678
    Bolsover, Derbyshire
    Help please, our electric step (Apollo 2000) fitted on our 08 Hymer, works fine, but the sensor to say it is in must be faulty, the control panel will not stop flashing and beeping, driving us and the dog bonkers even with the radio turned up
    I am useless at DIY and if it cant be fixed with WD40 I wont take it on!! I presume it must have a switch of some kind to detect the step is retracted, I have looked but cant see anything obvious, or any accumulation of dirt etc
    As I do not think I am going to fix it, does anybody have any idea how to turn off the control panel while we are travelling until I can get it looked at by somebody who knows what they are doing
    Biggest issue we could not be much further from home, just arrived in Durness, it was fine on our journey to Grantown a few days ago, it has been cold but things have warmed up again now
    David
  2. davejen
    davejen Funster
    Aug 21, 2008
    1,248
    699
    Kirkpatrick Fleming Dumfries
    Usually it is muck in a connector, so check again and pull any apart, clean with contact cleaner- not WD40, sorry, and put them together again and test. Other than this not sure, but worth a try.
    Cheers, Dave:thumb:
    • Like Like x 1
  3. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,520
    12,678
    Is a jet wash good enough? my kind of cleaning. To get to connectors I need to be under MH, this involves direct contact with wet and cold ground and I still might not see what is wrong unless it happens to be glowing!
    I reckon a sock or towel taped over the control panel might just do it till we get home, just need to check mirrors to make sure I really have retracted step, used to depend on the beeps!!
  4. hilldweller
    Dec 5, 2008
    26,903
    25,759
    Macclesfield
    I would go in the LH locker and get out the bright yellow two piece waterproof oversuit and the rubber backed picnic blanket and get on with it.
    • Like Like x 3
  5. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,520
    12,678
    Luckily for me mine did not come with that option, I chose the empty locker to save weight
    • Like Like x 2
  6. Larby
    Larby Funster
    Jun 17, 2012
    1,699
    3,929
    North Essex
    Is there some crap or a stone or something stopping the step from being [HI]fully [/HI]retracted?
  7. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,520
    12,678
    It must be something simple like a blockage or a broken sensor. I feel obliged to have a better look in daylight again tomorrow, hopefully I will find a stone or similar
  8. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,374
    9,819
    its a very common fault with road dirt building up on the limit switch. a jetwash with step open jetting at the back and between steps may well do the job.
    failing that google for a local auto electrician and get your wallet out
  9. hilldweller
    Dec 5, 2008
    26,903
    25,759
    Macclesfield
    When for the sake of an extra tenner they could use a nice sealed proximity sensor !
    • Like Like x 2
  10. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,520
    12,678
    Thanks, I am unlikely to find a jet wash up here, not sure that Google can do much for us so far off the beaten track, the tea towel might have to be the answer till we get home, I did try driving through puddles today, nothing has changed as of yet
    Just in case anybody is local and knows better I am in Durness, Highlands, any auto electrics man who can fix us will save my sanity on the drive home. 500 miles of beeping and flashing might just send me over the edge
  11. JockandRita
    JockandRita Funster Life Member
    Aug 2, 2007
    5,782
    7,587
    Lincs/Cambs border
    It may not be electrical at all. :Smile:
    For example, on our MH, it was the handbrake cable to the rear brake drums, that caused the step not to house fully, thereby causing the warning buzzer to sound when the engine was started. Admittedly, older technology, but it might be worth a try.
    When stood outside the habitation door, engage the step retraction switch, whilst giving the underside of the step a bit of an upward boost with your left or right foot, depending upon preference. :Wink:
    This will help the step to retract fully, (as well as compressing the microswitch fully), thereby disengaging the sensor/alarm/buzzer. :thumb:
    BTW, WD40 is fine as a releasing or ant-icorrosion agent, but not as a lubricant. :Sad:
    Good luck with it.
    Jock.
    P.S. I couldn't identify an Apollo 2000 electric step, even when adding Autotrail to the search. :Sad:
    • Like Like x 1
  12. TheBig1
    Nov 27, 2011
    7,374
    9,819
    as for stoping the beeping over night or driving home, just pull the fuse out
    • Like Like x 1
  13. Granjan
    Granjan Funster
    Aug 4, 2013
    840
    5,877
    Yorkshire
    Hi David,
    There is some info about location of fuses if you google "Hymer electric step problem" it is on the wild camping forum from 2011.
    Probably no help ......but maybe it will turn off the noise, or reset it if you manage to flush it clean.
    All the best.
    Janet
  14. coldstreamer
    coldstreamer Funster
    Feb 1, 2011
    209
    146
    Redcar
    We have had our present Hymer for 12 years and its a regular job to use the hose on high pressure under the double step. Then when its dried off give the connectors a good dose of WD and Bingo! away it goes.
    Always a problem in the winter with all the crud off the roads.
    Best Regards Mac
    • Like Like x 1
  15. camocam1
    camocam1 Read Only Funster
    Aug 28, 2012
    1,112
    783
    Elgin,Moray,Scotland
    J & G Sutherland, the garage ,crescent St, halkirk , Caithness 01847 831208
    Give these guys a phone not sure for detonate but probably about 15 miles from Furness
    Worth a try
  16. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,520
    12,678
    Not sure now where I dreamt up the Apollo bit, somewhere between going out to read the name and getting back to type it, the name changed from Project (correct name) to Apollo!!
    Thanks for other advice will be giving it a kick in a bit
  17. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,520
    12,678
    Its a beautiful day up here, blue skies and sunshine, off to look / spend money at craft centre, then further investigate step
    Fuses always worry me, what else is on the same circuit, handbook is next to useless as it covers all models
    Will be adopting the foot assist method later
    Thanks to all for input, it really helps to have additional opinions :thumb:
    David
  18. JockandRita
    Aug 2, 2007
    5,782
    7,587
    Lincs/Cambs border
    David,
    Which is your model of step? They look very similar to Omnistor Thule models.
    With the step deployed, check the operation of the microswitch by hand, whilst the buzzer is sounding. If that has the desired effect, where retraction of the step doesn't, you may have to adjust the microswitch, or it's point of contact with the step framework. This is assuming that the step's movement isn't being restricted in any way, as I suggested earlier in the thread.
    Regards,
    Jock.
  19. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,520
    12,678
    Thanks Jock
    I am now quite a lot more informed but no further forward. I have been underneath, can't add any more to the model than earlier Project 2000 and Hymer are the only logos
    But I have now found the microswitch, it looks like a short pencil, rubber covered with a round end that I can feel a click when pressed. It does not stop the beeper though when pressed
    Quite a job even to check this though, the controller beeps due to mains hook up, sorted that, then beeps due to door open, then you can't hear the beeper with door shut and engine running (beeper does not come on with just ignition, engine has to be running)
    Alignment of the switch looks perfect, when step closed is makes good contact anyway.
    I have a found a taped up connector in the wiring above the step area, wary about taking this apart, worried the power to the step might be lost, then will be stuck in or out!! It feels like you can push the step manually, do you think this might damage the motor?
    I am now resigned to muffling it with a tea towel for journey home then having it looked at with annual service which is due when we get back.
    Not keen to remove fuse as not sure what else might be lost with it, knowing my luck it will be critical
    David
    • Like Like x 1
  20. davejen
    davejen Funster
    Aug 21, 2008
    1,248
    699
    Hi, David, sounds like you may have found the problem- the microswitch should cancel the buzzer when pressed. Looks like you will need a new switch. Can you remove the wires and join them together? this should cancel the buzzer and prove the switch is caput.
    Cheers, Dave:thumb:
    • Like Like x 1
