Step has stopped retracting when engine turns.
Discussion in 'Motorhome Chat' started by Welsh girl, Oct 11, 2015.
  1. Welsh girl
    Welsh girl Funster Life Member
    Nov 7, 2009
    2,711
    1,316
    living the dream.
    I've found the fuse which I changed, it worked once now it had stopped again.
    The fuse hasn't blown and the wiring is connected to a black round plastic thing which has 2 spade connectors going somewhere else.
    A little beeper goes off but the step won't retract unless manually done with the rocker switch.
    Anyone know what else I can try please?
    It will come in and out with the rocker switch.
    • Like Like x 1
  2. andy63
    andy63 Funster
    Jan 19, 2014
    2,065
    7,844
    south shields
    There are a couple of possibilities which come to mind that may cause that..
    There should be a relay that closes the step on ignition or engine run..
    If you can locate that then you would be able to check the supply to the relay from the ignition or engine run supply..
    The step will also have a switch built in (S2 in the photo )which will ground the relay operating coil.. If that switch is stuck open then the relay will not operate and can't close the step.
    To help find the relay there should be a wire from the rocker switch running to it..
    Try and post a picture of the wiring I'm on about and hope it helps..
    Ta Andy
    • Like Like x 2
  3. Welsh girl
    Nov 7, 2009
    2,711
    1,316
    living the dream.
    Thanks Andy. I'll look tomorrow. I didn't get this till 23.19.
    Bedtime.
    • Like Like x 1
  4. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,830
    13,567
    Bolsover, Derbyshire
    Leave it alone, the beeper is enough to remind you, I once nearly broke Bevs ankles, started engine while she was getting into MH still stood on the step
    That was our old MH, new one has not got auto retract, it just beeps at me (sometimes) good enough for me, always check in mirror when pulling away just in case beeper hasn't beeped (y)
    • Like Like x 2
  5. andy63
    andy63 Funster
    Jan 19, 2014
    2,065
    7,844
    south shields
    hi david, I thought it was a requirement that the step auto retracted... obviously not if yours was like that from new...
    ta andy
  6. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,830
    13,567
    Maybe mines bust as well, but Bev is happier that way :D:D
    Seriously though, if it is a requirement it really should have an interlock so if door open and probably therefore step might be in use, it shouldn't retract
    No idea on the 'should retract on start up' bit though
    • Like Like x 1
  7. andy63
    andy63 Funster
    Jan 19, 2014
    2,065
    7,844
    south shields
    just remember when putting my step in doing some reading, and the minimum European requirement was that the step should close on ignition on , or engine run... the more expensive option was to fit electronics that worked off the door switches..
    anyways as long as Bev is happy(y):D...and I see you are trying to off load a genny, shame on you...you may need both of them one day...:reel: :imoutahere:
    good night ...
    • Like Like x 1
