step and fridge packed up (1 Viewer)
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
Hi All,:thumb: now back from France after new engine fitted :cry:£££££££££:shout: but 12v not working on fridge also step not retracting on start up any body any ideas please I couldnt handle any more dramas so I just left things as they were and hoped for the best I have checked the fuses and they seem all ok.
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
did both stop working at the same time?
Did the step and fridge stop working at the same time?
Usual things to do check fuses .. also see if the spades are dirty as well as looking for blown fuses
check that earth straps are OK and clean
Is there a master switch off anywhere?
Bob
fusbill
36
7
Warwick
I'd second the first reply. When the fuse went on my step a while ago it affected the 12v fridge as well.
fusbill
Feb 25, 2008
232
96
Barril da Alva, Portugal
Caravan
on and off for the whole of my existance
Power out!!!
Hi, did they both stop working immediatly after the engine was fitted???
If so, then just maybe the wire that feeds the fridge via a relay under the bonnet may have been disturbed. Check the wiring and relay there and if not maybe a fuse elsewhere in the system that is maybe not so obvious.
Happy hunting
Cheyne
TheBig1
17,604
43,079
the fridge is powered by a relay, that energises when it gets a signal from the alternator that the engine is running. Its quite possible that the aux wire (thin) to the starter was missed off when fitting the new engine
have seen several power steps get their retract signal from the fridge power circuit as it tends to be near the door
check for a fuse gone first then trace the signal wire and ensure its connected
43,304
49,293
sounds like the engine fitters didn't reconnect the battery connections for the fridge and step relays to me.
have a look around the battery area for disconnected wires
Aug 21, 2008
693
1,357
Lincolnshire, UK
Autosleeper Symbol
Van Conversion
Step Problems
I suppose you've checked but in case you don't know, on auto trails the automatic step fuse is in the engine compartment.
I had a similar problem on my cheyenne after travelling through a bad rain storm
Alan:thumb:
mike mcglynn
mike mcglynn
Jan 6, 2008
2,700
32,552
A long time now
step and fridge update
All is now working it took an auto electrician about 10 minutes to find fault and fix it was a very thin black wire had been snapped off the negative side of the battery to the split charge relays :Smile:
