Steering probs help
Discussion in 'Swift Motorhomes' started by shifter, Aug 26, 2009.
  1. shifter
    shifter Read Only Funster
    Jan 18, 2009
    68
    wee island across pond NI
    hi all could someone tell me why the steering on my fiat ducato swift kontiki has started to make a banging noise every time i turn the wheel.it used to do it only when i held it on full Lock but has started to do it any time i turn the wheel now.:Confused:
  2. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,190
    16,659
    Liverpool.
    Hi,does it make the banging noise when the wheels are stationary or when the van is moving?
  3. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,270
    5,253
    East Sussex 01-580-881288
    Geo is the man to answer that.
    Peter
  4. pudseykeith
    pudseykeith Read Only Funster
    Nov 5, 2007
    382
    105
    Leeds West Riding of York
    Get it looked at by an engineer. Chances are that a drive shaft U/J is badly worn and is in a state of collapse .:cry:
    Pudseykeith
  5. St.Cyr
    St.Cyr Read Only Funster
    Aug 23, 2009
    49
    3
    West Wales/Normandy
    Hi. Can't remember if the Ducato has Mc'Pherson strut front suspension? If so it's the same as on the old Peugeot 404/504/505. I've owned dozens over the years and 3 or 4 of them developed a loud bang (after high mileage) when turning the wheel, as you said starting on full lock & getting worse. It was the coil spring moving in its top mounting... Just a possibility... :thumb:
  6. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,611
    238
    Gone RVing
    Hi.
    Consistant click or bang when on some form of lock, most likely CV joint. Single, could be the spring, a good look may reveil (show up, can't spell) evedence of movement, or it could even be a ball joint that's dry, ie OK straight ahead but of center dry and the bang is momentary siezing of the joint. There is I suppose another option, engine/gearbox mountings worn and the stresses of low speed manovering being to much. Jack it up and have a good poke, or garage time and probably sooner than later.
    Good luck:thumb:
  7. bazfergy
    bazfergy Read Only Funster
    Apr 20, 2009
    566
    3
    dumfries scotland
    I agree with dodgey get it to a pro before it becomes a major prob:thumb:
  8. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    Agree totally.
    Dave:thumb::thumb:
  9. olley
    olley Funster
    Jul 29, 2007
    3,751
    2,198
    Ipswich
    Hi if you get a knocking sound when you turn the wheel as you are moving, that's normally a cv joint, often caused by the rubber boot splitting and letting the grease out and the crap in. Fairly straightforward DIY job.
    Olley
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,714
    17,330
    YO11 2BD
    could be one of three things.....
    1....power steering pump on its way out. metalic grating noise...new pump.
    2....suspension strut top bearing dry and failing.....bottom of coil spring is turning but the top isnt until it has enough torque to force it to turn...a loud 'twanging' sound usually only noticed when stationary turning steering into lock.....common fault on older ducato's (mine does it occasionally)and no quick fix....new bearing.
    3....and most likely.....failing/failed Constant Velocity joint.....only does it if moving and will be a steady metalic knocking sound getting faster as you go faster....New CV joint.
    MOT failure item i believe.
