Steel Wheel Centre Hub Caps removal?
Discussion in 'Tech/Mech General' started by dna, Jan 25, 2015.
  1. dna
    dna Funster
    Jan 17, 2010
    197
    203
    Cheshire
    Help please - time for an idiots question!
    I have bought full wheel trims to improve the look on our motorhome (from the German dealer recommended in other posts).
    As the weather is good today I thought I would get round to fitting them. However, I have failed at the first step!
    The small central hub cap looks similar to the one in the first picture.
    It has the cut out round one wheel bolt but not the rest.
    The question is, am I right in thinking I have to remove four of the wheel bolts to get the cap off?
    In which case is it also correct that the bolts will be ok to put back without the cap? I cant see that the trim is under the pressure to hold the wheel on.
    Is there a way to remove the cap without undoing the bolts? The replacement trims will go over the bolts.
  2. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,643
    3,477
    Telford, Shropshire
    Yes, yes and no.
    Yes you need to remove four bolts to remove the centre cap, yes the bolts will go back in without the cap, they clamp against the wheel not the cap. No there is no way to remove the cap without removing the bolts, well not without destroying it in the process. Don't forget to torque the wheel bolts up again afterwards, 160NM for 15" wheels and 170NM for 16"s.
    D.
    • Like it Like it x 2
  3. dna
    dna Funster
    Jan 17, 2010
    197
    203
    Cheshire
    Thanks for confirming it. One of those things that seems obvious but a second opinion makes me much more confident.
    • Like it Like it x 1
  4. Chockswahay
    Chockswahay Read Only Funster
    May 29, 2012
    3,097
    4,801
    @dave newell lvs
    Dave, I am interested in this thread as I intend to fit four of the smaller caps that I have but can't get the wheel nuts off (well to be honest I have been put off by the cold and lack of proper torque wrench :unsure:)
    Do you have any advice on what type of torque wrench to buy please? (local garage want about £40 quid to take the wheels on and off :eek:)
  5. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,234
    15,220
    Leeds the one up North
  6. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,991
    1,993
    Warwickshire
    I use one of these to get the studs off:
    http://www.halfords.com/motoring/ga...dvanced-professional-breaker-bar-24-1-2-drive
    And one of these to do them up again:
    http://www.teng.co.uk/1292ag-ep-teng-tools-1-2-drive-40-200nm-torque-wrench.html
    I did not pay as much as this, but I have had mine for a few years now. You will also need a decent quality socket spanner (the impact spanners are toughest) and possibly a 1/2" drive extension bar to get the wrench far enough away from the wheels to move it.
  7. Chockswahay
    May 29, 2012
    3,097
    4,801
    Hmm....... thanks chaps........... not cheap eh? :eek:
  8. Techno
    Jul 28, 2010
    14,234
    15,220
    What size wheels do you actually have? as the pictured hub cap is for 16" but the trims you show are for 15"
  9. dave newell lvs
    Oct 31, 2008
    2,643
    3,477
    Telford, Shropshire
    Andy is correct, my apologies for erroneous info on torque, 16" wheels are indeed 180NM.
    D.
  10. Techno
    Jul 28, 2010
    14,234
    15,220
  11. dave newell lvs
    Oct 31, 2008
    2,643
    3,477
    Telford, Shropshire
  12. Archer
    Archer Funster
    Oct 2, 2012
    150
    170
    Shoreham by sea
    160 for this and 180 for that what happened to the good old days when you used the spanner that come with the car etc put it on and jumped up and down on it till it stopped moving:LOL::LOL:
  13. dna
    dna Funster
    Jan 17, 2010
    197
    203
    Cheshire
    I've delayed the job until I can borrow or buy a wrench.
    The wheels are 15". I used the first photo I found for the centre cap without realising it is for 16" wheels - it was the removal method I wanted to check. I had ( forlornly) hoped to just lever the cap off, clean the wheel and fit the new trim.
    Thanks to all for the advice
  14. Techno
    Jul 28, 2010
    14,234
    15,220
    Yes I found the 15" version (y)
    [​IMG]
  15. C200JK
    C200JK Read Only Funster
    Dec 27, 2014
    963
    3,174
    Ireland / London
  16. hilldweller
    Dec 5, 2008
    27,880
    26,949
    Macclesfield
    Works for me.
  17. Techno
    Jul 28, 2010
    14,234
    15,220
