Status Ariel box no power and not working
Discussion in 'The Beginner' started by themountaintiger, Apr 16, 2011.
  1. themountaintiger
    themountaintiger Read Only Funster
    Sep 27, 2009
    355
    63
    Lancashire
    Dont know if anyone can help me with this one. Not had problems before today, when I came to switch on status ariel box so the red light came on, no light came on. Checked TV and its not tuned in properly, so presume it is in fact that no power is going to the box. Can I ask, is that the only failure i.e. the power cable or is there something inside the box itself which can go wrong? Do I need to take the box apart in some way...looks like s sealed unit but cant tell due to its position in clothes cupboard..any help appreciated
  2. themountaintiger
    Sep 27, 2009
    355
    63
    Lancashire
    just noticed new icon (to me) on control panel which is fuse needs replacing...will get back to you if that fixes it
  3. themountaintiger
    Sep 27, 2009
    355
    63
    Lancashire
    yep it was the fuse..
    eeeee...you learn something new every day......
  4. hilldweller
    Dec 5, 2008
    27,505
    26,587
    Macclesfield
    Time to learn something else - why did that fuse blow ?
  5. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    look a that an answer straight away, see there are intelligent people on here:Rofl1::Rofl1::Rofl1::Rofl1::Rofl1:
    glad you got it fixed.
  6. slobadoberbob
    slobadoberbob Read Only Funster
    Jun 1, 2009
    6,159
    1,970
    Kent, garden of England
    But as Brian said.....
    But as Brian said.... Why did the fuse blow! Now there has to be a reason, that is now the question, not the ability to change it... Fuses are there to protect the item.. Made to blow when the unit or wiring has a fault.
    Time to get the test meter out me thinks
    Bob:Blush:
  7. themountaintiger
    Sep 27, 2009
    355
    63
    Lancashire
    Reason for fuse blowing.......
    Last week I was on hook up. Misses (god bless) had to wash her hair and plugged a 12v hairdryer into 12v supply. I said it wouldnt work as I thought (please note im posting in beginners forum so I'm allowed to be thick) that the 12v supply wouldnt work if I was on hook up. Anyway the hair dryer did work and I said to the misses guess what?? yes "you learn something new every day", by the time id finished the sentence the hairdryer had gone off.
    Id not give it a second thought till replacing the fuse just now and then the memories came flooding back (well in my case perhaps a slow dribble) and so id guess that was the cause...
    I suppose my question is then can you use 12v whilst motorhome being connected to power supply.
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,087
    17,751
    YO11 2BD
    you certainly can......
    but the hairdrier was probably too much for the fuse.
    the 12v socket would only be rated around 10amps and the drier may be 15amps or more.
  9. themountaintiger
    Sep 27, 2009
    355
    63
    Lancashire
    Do the cab 12v's work as well? Im on 2007 fiat ducato...or would they not work on basis of them draining cab battery.....?
  10. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    why use a 12volt hairdryer when you have a mains hookup????????????:Doh::Doh::Doh:
  11. themountaintiger
    Sep 27, 2009
    355
    63
    Lancashire
    didnt have a 'normal' hairdryer with us at the time. So it was that or nothing i suppose.
    Just bought one today
  12. pappajohn
    Aug 26, 2007
    30,087
    17,751
    YO11 2BD
    some do, some dont until the ignition is turned to ACC position or engine running.
    depends how it was wired.
    and yes...it will flatten the engine battery in time.
