Status Aerial
Discussion in 'Motorhome Chat' started by talaris, Jan 19, 2014.
  1. talaris
    talaris Read Only Funster
    Aug 17, 2012
    89
    25
    Cornwall
    The radio reception is my Dethleffs is quite frankly abysmal on the move. Loses signal and never stays on channel I know the aerial is probably poor or non existent!
    My status aerial has a vhf output. Can I use this to provide an aerial source for the cab radio? I see no reason why not but any views.
  2. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,090
    2,931
    Kendal, Cumbria
    You can do no harm by trying it. I'm never sure whether they're designed for VHF radio or VHF TV - either way it's worth a try. Where is the existing radio aerial?
  3. hilldweller
    Dec 5, 2008
    27,284
    26,276
    Macclesfield
    Our radio was performing very badly, I traced it to the aerial plug loose in the radio.
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,952
    17,629
    YO11 2BD
    as was ours..but i traced it to the cheapest crap radio Fiat could source at the time. :Rofl1:
    • Like Like x 1
  5. talaris
    Aug 17, 2012
    89
    25
    Cornwall
    No idea where the aerial is but I suspect it the cheapest rubbish that they could source. That is of course if there is one at all as the lead seems to nowhere really.
  6. SuperMike
    SuperMike Funster
    Apr 28, 2010
    1,013
    1,131
    St Albans
    Status ariel. :Rofl1:
    Hang a piece of wire out the window, it will do better. :Cool:
  7. pappajohn
    Aug 26, 2007
    29,952
    17,629
    YO11 2BD
    you may be right.
    Fiat stuck the aerial in one of the door mirrors at one point but as you have an A class it doesnt have the original mirrors..
  8. andyman
    andyman Funster
    Sep 23, 2007
    1,150
    507
    Leicestershire
    I connected the cab radio to the Status aerial. As long as the amplifier is switched on reception is very much improved.
  9. Caztur
    Caztur Funster
    Jan 31, 2009
    339
    141
    Shropshire
    I thought the radio was poor on my Romahome as sometimes I had to re-tune as it lost the signal - but it was brilliant compared to the one on my new Ducato based Swift which comes and goes constantly. The aerial appears to be just in front of the driver's side door pillar, it looks similar to the ones on the cars - but of course they are stuck on the roof at the back of the car. I suspect the van itself blocks the signal most of the time.
    Is it feasible to connect the radio to the TV aerial instead, but still keep that connected for the TV? That's on the roof so may pick up a better signal. Or would getting the radio one moved up higher be better?
    Or is it just the cheap Fiat radio? I wouldn't have though it could be any worse than the cheap Citroen one in the Romahome! (Which was actually quite good most of the time).
    Mmm, must change the avatar and motorhome details!
  10. talaris
    Aug 17, 2012
    89
    25
    Cornwall
    Def not in the mirror. It may be in the pillar. I have just bought a Calearo window aerial so will try that first.
  11. Dubiousp
    Dubiousp Read Only Funster
    Jul 3, 2012
    233
    45
    Hampshire
    The Boxer aerial well cut off bit of cable was in the pillar. I installed an aerial in the little qtr panel down by the bonnet, to be honest for the effort is its rubbish
    Ive tried all the connections I can only assume its the overhang that gives me the problem, my car however with a silly stick on Pure aerial is brilliant I wonder if its worth trying
  12. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,844
    3,343
    Eastbourne East Sussex
    My MH (A class) has an aerial on the roof which may have been an extra, it never worked well with the Sony radio, but that died recently and was replaced with a Lidl special with bluetooth, usb input, SD card slot, all for less than £50 and works fine with the same aerial.
  13. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,518
    Tyne & Wear, sometimes..
    I changed the original Blaupunkt radio in our 2009 Peugeot Boxer, it made quite a difference to the radio signal particularly on MW and LW.
    However I now just connect my iPhone via the auxiliary in jack on the new radio. Crystal clear reception via the fee app "TuneIn Radio" and no need to retune any more....:thumb:
  14. freelanderuk
    freelanderuk Read Only Funster
    Sep 24, 2009
    1,022
    541
    Saltfleet/Lincolnshire
    i have connected the cab radio to the status amplifier box by means of a 5 meter Ariel lead and it has made a vast improvement to the signal whilst driving , once parked up its just as good and we can now listen to the radio:BigGrin:
    • Like Like x 1
  15. mentaliss
    mentaliss
    Nov 2, 2012
    657
    307
    Lancing
    Your best option is to fit a proper external aerial to the windscreen pillar, as was fitted on my previous Rapido, my Dethleffs also has a black one fitted in the same place...... radio reception is fine:Cool:
  16. Dubiousp
    Jul 3, 2012
    233
    45
    Hampshire
    Yes its interesting that my friend has a fixed wip on the pillar and an overhang with cab bunk his works fine I cannot seem to find the details of the manufactuer though
    Any ideas
