Status aerial (1 Viewer)
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
Having some probes getting a picture in some of the places we are in atm as its remote at times , so I'm looking to get the most out of our status aerial that is installed on Wendy ( our MH )
So what is the difference between the aerial being horizontal vs vertical - how do I know when to put it vertical.
Also there are like 2 periscope aerials that you can pull out of the rear of the aerial itself . But this involves a visit to the roof , so what's the crack with them, what are they for .
43,329
49,444
The extendable bits are for radio reception.
Horizontal and vertical polarity......main transmitters transmit on one polarity and repeaters transmit on the other polarity.
You can get a signal if the wrong one is selected but its very hit n miss.
Google UK tv transmitters and You’ll get a list of what transmitter is on which polarity....but you do need to know which mast area you are in.
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
Wherever you go try and see which way the aerials on houses you pass are pointing and what orientation they have.
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Thanks papajohn . Glad to hear them parts are to do with the radio.. Save me a trip to the roof :)
I forgot I've got an app for aerial transmitters I'll have to see if I still have it,, and I'll check out Google :)
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Yip I do try to do that , but not many aerials down here .. Mostly sat dishes
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Just looked at the app I forgot I had installed , it's called UK aerial alignment
Shows my closest transmitter 43km away, I don't think it lists antennas in the south of Ireland , anyway it says the following info about that transmitter bearing 117.4 degrees Pol :V Aerial group B
I take it that the " pol v " means its vertical ??
Jaws
23,836
72,477
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Yes, vertical polarisation and the group B refers to the channels it is transmitting.. From 35 to 53
Though since digital went live an awful lot of transmitters are using virtually all channels ! ( 21 to 68 so a wide band antenna as fitted to just about all motorhomes that have an antenna )
Where abouts are you Bart ?
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
@Jaws Dunfanaghy in Co. Donegal atm.. got a super reception last night where we are parked over looking some water :)
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
If in doubt with vertical/horizontal set it to 45 degrees and you'll get both then when on channel try H and V to see which is best.
Jaws
23,836
72,477
Thetford Norfolk
C class, Chieftain
Ahh.. You doing the Wild West route perchance ? I know the place you are at I think.. Overlooking Sheephaven Bay ?
Bet its a bit chilly there at the moment !!!
You are pretty close to the Hollywell Hill transmitter.. It is vertically polarised :)
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Currently at Magherhoraty harbour ..lovely beach . just walked it . 4.5 km return walk . all pure sand :)
