status aerial leak
Discussion in 'Motorhome Chat' started by camocam1, Jan 23, 2014.
  1. camocam1
    camocam1 Read Only Funster
    Aug 28, 2012
    1,112
    783
    Elgin,Moray,Scotland
    When I was away last weekend there was very heavy rain, no leak from aerial until I slackened it off to lower it and the water poured in down the pole. Have had a look up on the roof and all seems sealed ok so anyone got any ideas am I missing a rubber seal somewhere ??
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,189
    15,163
    Leeds the one up North
    The cold aluminium pole can attract a lot of condensation inside. It may simply be the case at this time of year
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,120
    17,789
    YO11 2BD
    not missing a seal (it would leak all the time) but it may have dried out or perished.
  4. camocam1
    Aug 28, 2012
    1,112
    783
    Not condensation techno as was like a river, will try and check seals again papajohn
  5. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,782
    10,198
    there is a flexible plastic collar on the roof that the pole passes through. this is several mm above the roof level though. if water pools around it, the sleeve can fill with water, held back by the clamp. when you slacken the clamp, wayer can pass through
    slide the aerial and pole out through the hole and thoroughly clean the apateur and pole. grease with silicon grease and reassemble. if the leak carries on you will need to replace the sleeve and seal as they are bonded together
    • Like it Like it x 2
  6. camocam1
    Aug 28, 2012
    1,112
    783
    Thanks big1 that sounds like it job for the weekend
  7. TheBig1
    Nov 27, 2011
    7,782
    10,198
  8. Techno
    Jul 28, 2010
    14,189
    15,163
    Did it leak down the outside of the pole or the inside?
    Mine shed water down the inside from the jolt of pulling it back down and being the long pole it was quite a puddle.
    If it is the roof seal it will leak down the outside of the pole
  9. camocam1
    Aug 28, 2012
    1,112
    783
    It was down the inside of the pole
    • Like it Like it x 1
  10. Techno
    Jul 28, 2010
    14,189
    15,163
    Cannot be the roof seal then
  11. camocam1
    Aug 28, 2012
    1,112
    783
    So did you do anything or just leave it techno
  12. Techno
    Jul 28, 2010
    14,189
    15,163
    It only happens in very cold weather when the heating is on.
    Only happened once because I only use it if I can't get satellite so I just mopped it up.
  13. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,770
    2,710
    Tunbridge Wells
    Sounds like condensation of the air inside the pole.
