Starter Probs
Discussion in 'Tech/Mech General' started by rangitira, Sep 15, 2012.
  1. rangitira
    rangitira Funster
    Jun 30, 2010
    6,321
    12,791
    Cornwall
    :Angry:
    Brand new Battery, fully charged, Immobiliser recognises Key, live feed to starter (used tester) Wont start, wont turn over, not even a click:Doh: Panel lights do not fade when key turned to start position:Doh:
    Any Ideas on whats wrong?
    Rego = 02
    Donkey= Fiat 1.9 TDI
    Many thanks in anticipation:thumb: JohnMc
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,265
    5,249
    East Sussex 01-580-881288
    Starter solenoid not getting 12v or dud, try running a lead from battery to solenoid, does not need to be a heavy duty cable.
    Peter
    • Like Like x 1
  3. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    possibly a stuck brush, give the starter a tap with a Glaswegian screwdriver.
    • Like Like x 1
  4. scotjimland
    Jul 25, 2007
    28,936
    25,589
    Bad earth connection (corrosion) between battery and chassis and or engine block ..
    • Like Like x 1
  5. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,801
    1,025
    Cark, Cumbria
    When I had the same problem it turned out to be a bad earth,new earth lead to engine cured it.
    • Like Like x 1
  6. rangitira
    rangitira Funster
    Jun 30, 2010
    6,321
    12,791
    Cornwall
    Thanks to Peter (John Cross Motors), Scotjimlad, Roger Wildman, and Jay:thumb:
    Spent part of today buffing various Earth Wire ends, tried it, no workee:Doh: as a last resort changed to starter motor, (had a spare because I insisted on retaining the old one after the garage in Scotland said it was clegged, it wasn't, I had it tested,:Angry: it was A1)
    and!:thumb:It started ok!:thumb:
    So well done Fellas and many thanks:notworthy::notworthy:
    And it was quite fortuitous really, cause while I was grovelling around underneath I spotted a water leak:Doh::Wink:
    Which comes to the sticky bit, the starter I removed, was purchased new (nearly £500) on 13-6-11 (15months?) What sort of Guaranty is on new parts? Even though nothing is on the Invoice?
    Any Ideas?
    • Like Like x 1
  7. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,709
    17,323
    YO11 2BD
    generally 12 months from date of purchase.
    you could try it now its off.
    pair of jump leads.
    one to the motor body and earth term of a battery
    the other to the pos terminal of the battery then stand on the motor and 'flash' it across the opposite terminal of the starter motor solenoid that the battery cable is normally fixed to.
    put a couple of nuts on the terminal first or it will destroy the threads.
    stand on it 'cos it will have one hell of a flash and kick if it turns.
    if it turns, the solenoid is cabbaged...if it doesnt, the starter is cabbaged.
    • Like Like x 1
  8. Ralph-n-Bev
    Ralph-n-Bev Funster
    Nov 30, 2009
    5,943
    9,046
    Wrenthorpe, Wakefield.
    Glad you got it sorted .
    For a minute i thought it could have been the " fat arsed " warden you had an altercation with :Rofl1:
