starter battery..
Discussion in 'Solar Power' started by bilimanjaro, Jun 8, 2014.
  1. bilimanjaro
    bilimanjaro Read Only Funster
    Jan 29, 2014
    57
    22
    grimsby
    starter battery..
    three months back I bought two new leisure batteries,,and connected together..all ok..but the last few days I have noticed that on the regulator,, battery two starter battery is only showing some thing like 5.6 volts going in from solar panel..[75 watt] put tester on starter battery showing 12.5 volts roughly,, the van is starting ok ..and then showing with engine running 14 plus volts on regulator.stays on this,then drops down to roughly 5 volts is the regulator trying to tell me the starter battery is coming to its end..
    hope this makes sence..
    thanks in advance..​
  2. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    I'm not sure I'm quite getting this. What is reading 5 volts? If your engine battery at rest is showing 12.5V, then it is nearly fully charged. I suspect you either have a loose connection at your solar charger, or you are reading something other than volts, perhaps you are reading the charge current, or the voltage of the solar panels in low light?
