Starblazer habitation door lock
Discussion in 'Motorhome Chat' started by octopush, Mar 2, 2015.
  1. octopush
    octopush Read Only Funster
    Sep 28, 2012
    133
    51
    portsmouth
    I have a 2004 starblazer.
    The door door lock (habitation door) will only stay shut when locked is this the way it is or should you be able to push the door shut and then pull the handle to open it without locking it.
    It is a pain in the a## having to unlock it all the time.
    Thanks Rob
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,954
    There are various different types of habitation door handles/locks but all I've seen close without locking so maybe something has slipped/broken. O'Learys have a large range of the different types.
  3. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,670
    5,727
    Yr Wyddgrug
    Do you have a photo of the lock?
  4. octopush
    Sep 28, 2012
    133
    51
    portsmouth
    Hear are some pictures of the lock.
  5. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,238
    15,222
    Leeds the one up North
  6. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,670
    5,727
    Yr Wyddgrug
    The spring broke on my van's lock (same lock as yours). I bought some piano wire and fabricated a replacement, albeit, not the easiest task. Or, as Andy has indicated replacement locks are available at a price.
  7. Techno
    Jul 28, 2010
    14,238
    15,222
    Usually a lot more than that price too Phil.
    Yes indeed not easy to replicate at all but a locksmith might make light work of it.
    [​IMG]
    • Like it Like it x 1
  8. octopush
    Sep 28, 2012
    133
    51
    portsmouth
  9. Techno
    Jul 28, 2010
    14,238
    15,222
    Yes
    If this has just occurred then something has failed. If it has done it since fitting then it is not fitted correctly in some way.
  10. octopush
    Sep 28, 2012
    133
    51
    portsmouth
    Thanks Andy that's what I wanted to know.
    It was replaced just befor I got the camper so it looks like it was fitted wrong.
    I will have a look at it this week and see what they have done wrong.
  11. Techno
    Jul 28, 2010
    14,238
    15,222
    It can only be the position of the white tabs or they fitted a single tab unit. The position of the locking lever must play a part I imagine too
  12. octopush
    Sep 28, 2012
    133
    51
    portsmouth
    I will let you know what I find.
    Thanks Rob
  13. octopush
    Sep 28, 2012
    133
    51
    portsmouth
    Thank you all for your help.
    I found the problem it was the leaver on the door handle when I took the lock off the leaver inside the handle of the door was bent.
    all works as it should now.
    • Like it Like it x 3
