Stalling RV?!
Discussion in 'American RV's' started by juliandavies, Sep 29, 2010.
  1. juliandavies
    juliandavies Read Only Funster
    Dec 12, 2008
    73
    Crystal Palace, London
    RV has been running great since MOT a few months ago - been to Cornwall and back etc.
    But on my last drive it must have stalled about 6 times!
    Always seems to happen when I am going round a corner and braking.
    Obviously this is a little scary as brakes and steering loses power and I have to get into Park to re-start.
    Before I take it to the garage has anyone ever heard of this before?
    Jules :Sad:
  2. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    Dumb question, you have got plenty of fuel in the tank?
    Sounds daft but RV tanks are rather large and if you let them get low that would cause your problem?
  3. johng
    johng Read Only Funster
    Aug 15, 2007
    588
    Kent/Sussex UK
    maybe the brake servo is causing this.. just trying to think how ...
  4. wivvy's dad
    wivvy's dad Read Only Funster
    Jun 22, 2010
    3,218
    1,807
    48.066895,12.862673
    Don't brake in corners.
    One of the first things you learn in advanced driving - brake in a straight line.
  5. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,735
    5,966
    Mansfield,Notts
    1. Yes this problem is not new it happens on all sorts of vehicles Idle speed control valve/ mechanism possibly sticking
    2. Vac pipes split or loose
  6. Geo
    Jul 29, 2007
    9,735
    5,966
    Mansfield,Notts
    And the first thing you learn in a RV without steering, braking is a good option:Doh:
  7. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    Servo/vac probs, arn't the Chevy's on a hydraulic servo system off the power steering?
    I should know as we have the Chevy under our Winne but I've not looked:Blush:
  8. Geo
    Jul 29, 2007
    9,735
    5,966
    Mansfield,Notts
    Servo :Eeek:
    I thought they operated the brakes:Doh:
    What do I know:Doh:
  9. juliandavies
    Dec 12, 2008
    73
    thanks all of you
    seems like I just need to be careful until I get it to a garage!
  10. johng
    Aug 15, 2007
    588
    Kent/Sussex UK
    :Doh: yes Simon, I had problems with my PS pump and should have remembered this ..
    Geo, on a normal set up, brakes are applied (which are assisted by the servo) which in turn is powered by manifold or some other engine generated vacumn? I was just linking the application of brakes to a drop in vac, helping to cause a stall.. falls over of course on the chevy if it is brake boosted from PS pump :)
  11. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    Wished I hadn't googled this, info gleaned from various faults, including, pedal went to floor:Eeek:
    Anyway, generally it appears the P30 is hydro assist, power of the power steering pump but and also be a combination of power steering AND vacumn, though at a guess I'm thinking OPs will be power steering pump so in theory unrelated, however, if power steering pump was loading up during braking and cornering it could stop the motor????? Oil level, pump working to hard, mmmm, serious guessing there:Eeek:
    Julian, is there and strange (typically hissing) noises generally with the engine running or when you turn the wheels/press the brake pedal??
  12. juliandavies
    Dec 12, 2008
    73
    no strange noises...
Similar Threads
  1. Sarahchris
    303
