Stainless Steel Wheel Trims
Discussion in 'Motorhome Chat' started by GEOMAR, Apr 28, 2015.
  1. GEOMAR
    GEOMAR Funster
    Mar 22, 2015
    120
    65
    Aberdeen
    I recently bought a set of 16in. stainless steel wheel trims from a company on ebay called Sesame power windows for £82.50 and am delighted with them and would recommend them, the only thing is you will need valve extensions so you don't have to remove the trims every time to check or increase tyre pressures
    GEOMAR
  2. Old Soldier
    Old Soldier
    Apr 10, 2010
    902
    1,484
    Wells in Somerset
    Thanks for the tip, my old ones are looking a bit tatty on the rear. Lost their sheen, fronts are OK! Think it was something a "hand wash" car wash put onto them!
  3. GEOMAR
    GEOMAR Funster
    Mar 22, 2015
    120
    65
    Aberdeen
    Certainly value for money
    GEOMAR
  4. CJB
    CJB Funster
    Feb 26, 2013
    140
    60
    Kent
    I have just put a set of these on the van, they look nice, think I paid £220 ish http://www.parmagroup.co.uk/Product...inter-iveco-daily-ford-transit-trims-for-vans#.
    They are the next best thing I found to Euroliners who no longer exist.
    I could not find a way to make valve extenders look good hanging through the hole in the trim. So I fixed them with a bracket inside the wheel trim on the steel wheel (I have twin rear wheels), now I am adding the TypePal monitoring system so I only have to remove them when required.
    Not ideal but the best solution I could find.
  5. GEOMAR
    GEOMAR Funster
    Mar 22, 2015
    120
    65
    Aberdeen
    The trims I have are for single rear wheels only, the valve extensions don't need to be on all the time but only when required to check or inflate tyres
    GEOMAR
  6. GEOMAR
    GEOMAR Funster
    Mar 22, 2015
    120
    65
    Aberdeen
    My trims are for single wheels only and valve extensions don't need to be on all the time but only fitted when checking or inflating tyres
  7. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,647
    5,854
    Guisborough
    If you drill the drill the wheel trim the valve extender can come through the face of the trim, then you can use a flow through tyre pal in between two flexible valve extender pipes.
    • Like it Like it x 1
