Squeaky floor
Discussion in 'Motorhome Chat' started by bald eagle, Mar 31, 2009.
  1. bald eagle
    bald eagle Read Only Funster
    Jan 30, 2009
    528
    4
    here,there and everywhere
    We have autotrail mohican, and the floor has started to squeak by the
    cooker and sink unit, do any of you know how this is fixed.
    many thanks
    bald eagle
  2. madbluemad
    madbluemad Banned
    Jan 26, 2008
    3,341
    243
    spain
    We had the same on our Gulfstream. After a while we took the floor covering up and found that we had a leak. The floor underneath the covering was soaking and the water had been sealed in by it so we coudnt see it. The damp made the floor lift and creak If you have a lino type floor covering check under it you may have the same problem. Hope you havent.
    Jim:Smile:
  3. scotjimland
    Jul 25, 2007
    29,048
    25,741
    Suffolk
    Hi ..
    Could also be de lamination, usually where there is heavy traffic . ie sink and cooker. basically the polystyrene insulation under the plywood compresses and leaves a gap..
    It can be repaired by drilling from underneath (or above if you can lift the lino), into the area affected and pumping in expanding polystyrene foam..
    Jim
  4. Jim
    Jim Ringleader
    Jul 19, 2007
    27,012
    79,590
    Sutton on Sea
    Hi, if it is delamination it will get steadily worse. You can fix though, see here
  5. DJP
    DJP Read Only Funster
    Nov 4, 2008
    39
    Somewhere in Europe
    HI, You don't say how old the Mohican is. Is it a 2008 model or older?
    It is relevant to a floor delamination problem on some early 2008 model year builds.
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,389
    18,078
    YO11 2BD
    dont use the cooker then you wont need to use the sink so you dont need to walk on it...:Rofl1::Rofl1::Rofl1:
    sorry, couldnt resist.:Blush:
  7. paulus the woodgnome
    paulus the woodgnome Read Only Funster
    Sep 25, 2008
    640
    299
    Nottingham
    get rid of the mouse then it won't squeek
