Sprinter electrics
Discussion in 'Motorhome Chat' started by spongy, May 5, 2016.
  1. spongy
    spongy Funster
    Jul 29, 2009
    278
    95
    hampshire
    Yet again the electrics are playing up on my Sprinter. In its 8 year life it has had a new fuse board and relays, 2 new ignition switches and several visits to the workshop because of warning lights. I had it checked in February because it had ESP warning but £95.00 later they couldn't find anything wrong. It is again showing ESP warning and speedtronic cruise control warning "visit workshop". If I switch the ignition of and then restart everything is ok. Should I need to worry or is this yet another Mercedes gremlin. Anybody else had this problem.
    Spongy
  2. FJmike
    FJmike Funster
    Jul 17, 2014
    816
    869
    Swindon
    I had the abs asp light problem on my 2007 sprinter based Pilote . After several misdiagnosis and a few times not being able to start until fault cleared. The fault was tracked down by a local mechanic to corroded relays and wires under the dash.
  3. Mikescuba
    Mikescuba Funster
    May 2, 2016
    344
    548
    Rhone Alps
    On my work Sprinter van it has occasionally had a ESP warning light come on, and like you I just switch off the start up again and its cleared. It has been doing that since new. Its six years old now. I did have a problem with some sensors which caused a loss of power due to the system self protecting the engine. I had to have the exhaust sensor changed and a couple of others . No idea what they were but it sorted the problems out and improved fuel economy.
  4. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,748
    10,167
    i would be investigating the wiring to the fuse/relay board. if the last replacement was down to water ingress and corrosion the multiplugs may be corroded too.
  5. spongy
    spongy Funster
    Jul 29, 2009
    278
    95
    hampshire
    Hi the big1
    The fuse board was replaced due to corrosion, good point and may have that investigated
    Spongy
  6. spongy
    spongy Funster
    Jul 29, 2009
    278
    95
    hampshire
    Thanks for that bit of info, as the warning light does not come back on when I restart I think I will see how it goes. It doesn't affect the starting.
    Spongy
    • Useful Useful x 1
