Spray on Solar Panels
Discussion in 'Solar Power' started by rangitira, Dec 8, 2014.
  1. rangitira
    rangitira Funster
    Jun 30, 2010
    6,373
    13,140
    Cornwall
    Read a piece in the Facist Times that says some bright spark has invented "spray on solar panels"
    "Researchers in Canada have discovered a way of applying solar cells to flexible surfaces using minuscule light-sensitive materials.
    Known as colloidal quantum dots, the substance could be printed on to a flexible film and used to coat all kinds of surfaces from laptops to aircraft wings, Covering a car roof for instance would produce enough power for 3 100 watt light bulbs or 24 compact fluorescents
    The breakthrough system called "sprayLD" could send the prices of solar panels crashing!"
    So whatcha think? Wait awhile before I get 'em fitted?
  2. movan
    movan Funster Life Member
    Dec 2, 2009
    13,589
    24,546
    Moving around
    Sorry confused here again. If they coated something with the material, they would still need to attach it to batteries etc., so if something went wrong you would have the whole of the motorhome roof covered with something which wasn't working ,unless it is easily removed. Maybe that's a daft statement but it's my first thought, and
    • Like Like x 1
  3. Gromett
    Gromett Funster
    Feb 27, 2011
    8,080
    14,662
    UK
    I remembered reading something about the "colloidal quantum dots" from last year. Found out they were being used to make lasers and LED's.
    However back in May this came up.
    http://www.nature.com/nmat/journal/v13/n8/full/nmat3984.html
    I reckon we are still 10 years away from seeing spray on solar panels. I do recall that I was thinking about this just after I went fulltiming in 2009 probably 2010 ish. And 5 years on they are still not here :(
    Would be great though. If you are in to this type of stuff can I recommend the http://arstechnica.com/ website. regularly has great articles on this type of thing.
    And @movan, when the painted on solar panels get damaged, just spray a new coating on :whistle::LOL:
    • Like Like x 2
  4. Gromett
    Gromett Funster
    Feb 27, 2011
    8,080
    14,662
    UK
    I was sure I had seen this before so I went on the hunt..... July 2012..
    http://www.scoop.it/t/amazing-scien...films-leads-to-most-efficient-solar-cell-ever
    The source article is unfortunately only available as part of a PDF now though.
    These material scientists are getting as bad as the policitians for re-announcing discoveries as new years after they first announced them.. I am still waiting for my 100x battery at 1/100 the weight with 5 second charge time....
    • Like Like x 1
  5. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,074
    2,920
    Kendal, Cumbria
    I think I'd rather have a sensibly-priced LPG-fuelled fuel cell.
  6. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
    imagine spraying an entire van, miniscule additional weight and massive amount of leccy.
    • Like Like x 2
  7. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,575
    7,153
    Plymouth
    You wouldn't need the duct tape then . Would you ?:D
    • Like Like x 1
