Spluttering hot tap and a rumble in the TRUMA hot water tank (1 Viewer)
gavel
20
East Anglia
Low profile
4 years
I think I have an airlock in the hot water system. The hot tap runs for approx 1 minute and then splutters and I can hear the air bubbling in the tank. Any advice much appreciated.
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
Make sure the shower tap is open too- some people forget this one!
Cheers, Dave:thumb:
Sep 5, 2008
566
332
York
C Class Bessacarr 769
Since July 2010
We had that problem. I laid the shower hose on the shower floor and turned all the taps on. That cured it.
Lin
Munchie
8,921
12,581
Camping Les Vigeres
Font VendĂ´me
Since 2004
Another trick is to turn all taps off but one and blow down it. Easiest is take shower head off easier to blow down then. :thumb:
G
gavel
20
East Anglia
Low profile
4 years
airlock
Thanks for everyone's help I'll get busy tomorrow.
Jaws
23,836
72,461
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
It is also worth mentioning that it can take SEVERAL minutes of running the tap(s) to get the air out..
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
and generally its better to bleed the system cold.
and make sure you have closed the drain valves otherwise it takes for ever :Doh::Doh:
Jaws
23,836
72,461
Thetford Norfolk
C class, Chieftain
LOL !!!!
THAT made the fat man here laugh !!!!!!!!!!!!!!!!!!!!!! :thumb::thumb: ( yup, been there done it !! )
Minxy
32,646
66,530
E Yorks
Carthago Compactline
If it still does it afterwards, it COULD be some grit/filngs in the in-line filter for the inlet pipe under the sink - we had a similar problem with our kitchen tap (although it was the cold tap) and as it was thought to be a problem with the tap itself, when the pipes were disconnected to fit the new one the filter was found to contain some metal filings which had been caught in it as the system can't have been cleaned out after it was fitted, once they were removed it worked fine.:thumb:
