Split charge system when on mains hook up
Discussion in 'Tech/Mech General' started by JGriff, Sep 24, 2016.
  1. JGriff
    JGriff
    Sep 24, 2016
    Scotland
    Hi, I've recently purchased a converted van and have totally redone the 12v electrics but I have a query.
    I have fitted a smartcom unit to charge the leisure battery when the engine is running. And the previous owner fitted a "interpower 10amp" charger from a swift caravan to charge the leisure battery when on mains hookup.
    Would it be ok to fit a second smartcom unit but swap the input and outputs so that when on the mains hook up the "interpower 10amp" unit can charge the main van battery and the leisure battery simultaneously.
    Thank you for your help
  2. wigster
    wigster Funster
    Feb 4, 2016
    1,504
    859
    Not lost but not far off
    Have know idea sorry im sure others will help but :welcome4:anyway
  3. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,320
    8,028
    West Norfolk
    No reason why a voltage sensitive relay wouldn't work in the way you propose.
    The only problem I see is that with having two such devices, the 10 amp mains charger might not keep up with your leisure battery discharge in such circumstances. Both batteries would effectively become one big leisure battery wit both being connected to each other under mains charging conditions.
    Take out more than 10 amps over a period and you might well find you have 2 flat batteries rather than just the leisure battery.
    Therefore, no way of starting the engine until the mains charger has replenished both batteries to sufficient capacity.
    I would suggest you do away with the voltage sensitive relay for split charging and replace it with a conventional d+ alternator fed split charge relay. Then, use your redundant voltage sensitive relay in the way you describe to split your mains charging between the starter and leisure battery.
    This will ensure you can't discharge your starter battery whilst on site.
