Sparks Under Bonnet..... (1 Viewer)
troikafloyd
5
uk
Autosleeper Symbol 2004
Newbie
Hi,
Have just got back from a 20 mile trip in the rain and parked up...engine off, all ok. I then decided to move the van forward a bit and stuck the key in, turned it and sparks flew down from under the bonnet. I tried it again and now the engine won't turn, just a clicking noise. Has anybody got any ideas what could have happened or caused this?
Peugeot Boxer 2.0 Deisal Autosleeper Symbol 2004, 23,000 miles.
HELP PLEASE!
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
either your starter has shorted or your battery has expired have you opened the bonnet to see if anything looks obvious?????
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Probably popped the fusible link. Batteries are quite tight on these, and it won't take much for a loose connection to arc across.
Check that the battery is not 'swollen' or otherwise damaged. Then check terminals and ancillaries are all tight and have no arced out.
Next, check starter motor to see if connections are intact and tight.
There will be a loose lead or wire somewhere. Have a look at the fuse board too.
JJ
Mágica
May 1, 2008
19,253
47,963
Burstner Privilege T
over 50 years
Is your engine battery under the bonnet?
If so I would check the terminal connections are tight.
I suspect a starter motor problem.
Can you switch off everything, put vehicle in 1st gear (handbrake off) and see if you can "rock" the van a little (a couple of inches) to free off the starter cog which might have got stuck in the flywheel teeth. If you can turn the engine over a little way and especially if you hear a slight "clunk" of the starter motor thingy freeing off... try the engine again. (out of gear of course.)
Others will know more.
JJ :Cool:
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
JJ :Cool:
Sorry JJ, but...
NO NO NO NO!!!!!
Investigate or get investigated the spark source before doing ANYTHING else, especially putting the key in. As it appears at present to be started related, FIRST task pronto needs to be disconnecting the battery, earth (negative, typically black) first.
Then follow earlier checks.
One word, FIRE...
Jaws
23,830
72,333
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Just sounds like a battery terminal might have come loose to me.. as Nigel intimated :Smile:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
I second that hypothasii I second that hypithas I second
Shit me thinks ya right:thumb:
Geo
Not only loose but severely burnt:Eeek:
Sorry I meant starter conection
bigfish
348
84
Eastleigh, Hants
8 years, but had caravans & Tents before that
sorry jj, but...
no no no no!!!!!
investigate or get investigated the spark source before doing anything else, especially putting the key in. As it appears at present to be started related, first task pronto needs to be disconnecting the battery, earth (negative, typically black) first.
then follow earlier checks.
one word, fire...
please do nothing untill you have disconnected the battery, make it safe then look for the problem, 99% of electrical fualts are mechanical problems, i would do as others have said but make it safe first.
T
troikafloyd
5
uk
Newbie
:thumb:Thanks everyone for the advice / replies, I managed to start engine only after 'rocking' the van in first gear and spraying the earth strap connections with wd40. After turning off I again then tried to start it but again sparks and 'nothing'.
Do I presume it's the earth strap?
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Don't assume anything, get someone to carefully look where the sparks are coming from.
BUT sparks and WD40 do no mix, it's VERY inflammable. I once sprayed it on an arcing plug cap. Never again. It was like a flame thrower. Got away with it though.
Jaws
23,830
72,333
Thetford Norfolk
C class, Chieftain
I love wd40
I should think, over the years, it has earned me thousands...
people think it repels water.. well yes, but only for a short while then it attracts and absorbs it.. If you want to use WD-40 for anything other than cleaning jobs ( from work tops to hands .. ) you MUST refresh it every couple of weeks or so else it will do more harm than good..
If you wasnt to use something to stop corrosion use ACF-50 or similar.
It is not cheap but does actually do what most folk think WD does, andddd.. it is not highly flammable as Brian rightly points out
I would suggest you:
Open the bonnet and physically wiggle all and any big thick wires you see especially around the battery area
Do not go made, but give each a firm tug
Leave the bonnet open and get someone to try to start it while you watch to see exactly where the sparks are coming from
mid4did
526
727
N.somerset
Hymer Tramp R 655 GT
started in a minivan 1970's when I could fit into it.
[HI]
I second that hypothasii [HI]
[/HI][/HI]:thumb:
Geo
hear hear hic,I,ll have a drop of what you,re drinking :ROFLMAO:
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
[HI][HI]I love wd40[/HI][/HI]
I have to agree John, if my workshop manager finds WD40 in our workshop he goes spare...:thumb: Griff
