Spare wheel (1 Viewer)
shortfuse
38
Inverness
C
Hello All
Quick question-------Do any of you keep your spare wheel on the roof rack ? I know it would make the van a bit top heavy but at least I could get to it without taking a level 1 potholing course :Sad:
43,323
49,428
i wouldnt !!!!!
had to change my n/s/f at girvan on friday.
the bloody things heavy enough dragging it out from under the van and lifting it onto the hub without having to lift it down from the roof and putting the flat back up there and down again to get it fixed.
keep a bit of plastic sheet in a locker to lay on....damn sight easier.
ps......we were in Inverness on saturday :thumb:
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Many years ago I recall seeing a MH on a long distance tour in far off lands which had several spare tyres (not on actually wheels as I recall) so I suppose it could be done.
Raising and lowering even quite heavy things from the roof is not too difficult if you stand on the roof and use a rope. I used to carry all sorts of things on the roof of my old Kon-tiki (which has a very strong roof). Pity it's also famous for leaking though to be fair mine didn't.
S
shortfuse
38
Inverness
C
Many thanks for the thoughts ,You must have brought the good weather with you Pappa
regards sf
Johno
87
38
Kent
Low Profile
30+ with caravanning & camping
Just a thought would it be possible if you haven't got a bike rack to constuct a spare wheel carrier on the back of your MH preferably fairly low down to help with the lifting on and off.
John.
DESCO
2,646
266
London
low profile
18 years +12 years tugging
Hi Shortfuse.
Did this once on a previous motorhome, I was lucky I did not need it. I found it murder to get off again when I changed vans, Vowed I would never do it again.:Eeek: and I never have.
Dave
S
shortfuse
38
Inverness
C
Thanks again all------it will be one of these things I'll think about and never do anything with regards sf
Scotties
439
318
Norfolk
Hymer
Since 2006
Think Laterally ...
All the guys above are right, no one in their right mind likes lifting a spare one handed, at the same time as climbing a ladder.
BUT there is an answer, after sorting a suitable place for it to fit, open the Heiki (if you have one), and it's surprisingly easy to pop it on to the roof using both hands:Smile:
Slip a cover on it (all that sun), strap it nicely in place and 'Hey Presto' 26kg of ugly weight moved from beyond the back axle to much nearer the front.::bigsmile:
It may work for you too,:thumb:
Regards Richards
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
My spare is fitted to a bracket mounted at the back. Its a very basic affair and I reckon that even I could make one up and fit it.
I'm sure its posssible to whack it on the roof but I wouldnt fancy getting it down.
Jim
