Spare wheel access. (1 Viewer)
grymbo
43
13
South Ayrshire
Compass Avangarde 150
I'm a newbie.
Hi. I have a Compass Avantgaurd 150, 2009 reg and having a terrible time accessing the spare wheel. I can't see anything in the hand book that remotely resembles the spare wheel carriage let alone information describing how to access this spare wheel. Although the description given is written in English it completely incomprehensible. The van I'm sure as most of you will know is built on Peugeot Boxer base and has a 2.2 diesel turbo engine. Any advise would be gratefully received.:Confused:
Sep 26, 2013
4,169
5,154
Market Rasen
Self Build
Since 2003
Perhaps you could say where the spare wheel is located, is it also a Peugeot chassis with the spare wheel underneath at the rear?
Mike
brynric
730
1,553
Worcestershire
Pilote G600
By co-incidence I had to access the spare wheel from my Fiat Ducato this morning. It wasn't a happy experience.
The Fiat spare is carried under the van, in the centre just behind the rear axle. I don't know if it's the same on toys, there may be variations.
I have a long "jack handle" with a square end which passes through the plastic skirt and engages with a winding box which lowers the wheel. You then hook out the wheel and undo the nut which holds the winding cable to the wheel.
I did a fair amount of grovelling and knuckle scraping. I did eventually get it free and fitted the spare but it was a grubby experience. Swearing at the mechanism only helped a little.
If it's the same principle, best of luck.
Bryn
G
grymbo
43
13
South Ayrshire
I'm a newbie.
Thanks for all the replies. Sounds like the Fiat Ducata situation as described by brynric. Will have another go tomorrow and if unsuccessful will take some pics. Cheers Guys.:thumb:
TheBig1
17,630
43,253
my advice would be to ask a local tyre fitter to show you how to do it
I know on my van the bodywork makes it near on impossible to lower the spare. the easiest way is to slide under the van with a ratchet or spanner and turn the spool from there
otherwise call out the RAC or AA, whichever you are with to help change the wheel:thumb:
dogman
549
440
chepstow
Coach Built
I'm a newbie
That's what you pay for.
Mousy
3,485
20,319
Sa15 2DG
Hymer S840 Merc auto
Since 2013
I'm jealous, we don't have a spare wheel.:Sad:
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
We have a Boxer chassis with the spare underneath the van right at the rear.
I have managed to removed mine but it's not the best system I've seen. You need to unwind as much of the steel cable as possible so that you can slide the wheel out from under the body, if you have a long overhang I should imagine it will be near impossible.
As said get your recovery bod out and let them struggle. ::bigsmile:
G
grymbo
43
13
South Ayrshire
I'm a newbie.
Sorted! In the end called out the RAC. Everything fine now. Even know how to do it myself now:Doh: Thanks for the help guys.:thumb:
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
Glad you got it sorted, My First van had it underneath at the back but never took it off, the Second had none but a blow up thingy never used, this one has a spare in the garage, BUT it was only after I loaded it up to the gunnels going to Spain this year I realized it was in the far corner :Doh::Doh:, what a stupid place to mount it, I relocated it near the door at the first opportunity hopefully never to be used. Pete :thumb::thumb:
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Bryn
You're a brave man! We have the same carrier, I managed to wind it down to the ground but couldn't figure out how to get the wheel off the carrier, so wound it back up again. We have Peugeot breakdown cover, I'll ring them if we ever need to get the wheel off!
Allan
Moodybrook
802
651
Wet and cold place outside of M25
4 wheels and a pointy end
still in nappies
I had a go with mine and it is not the most desired job on the side of a motorway, pouring rain as it surely will be.
A tip for you, when lowering it, place a block of wood at the far side from what you are winding it down . So that the tyre lands on the block. This will tilt the whole wheel towards you, enabling you to get inside the wheel and get at the wee screw pin that needs to come out to allow tilting the suspension plate and releasing the wheel from the cable. Heavy lump of a wheel. maybe laying a mat under where the wheel will land, that also reaches to the outside of the van, pull the mat with wheel on it may make the job easier.
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Took mine off the Bracket, it now resides in the Locker! No way was I going to grovel underneath, trying to get it out on the road side!
AND!
I have more respect for the Breakdown Fellas to ask them to do it!
