Spanner in the Works (1 Viewer)
Incamania
47
27
Preston
Since 2002
:cry:
Does anyone know how to delete the spanner service logo from the speedo screen please?
The procedure in the handbook is known to be incorrect but I can't seem to locate the fix.
My van is based on the Peugeot '05' 2.8 Hdi chassis, which I'm told is really a Fiat. Does this alter things?
The van is not due a service until November - by either mileage or time.
Thanks in advance
Brian.
Jaws
23,832
72,343
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Just did my service sooo
here ya go.. :thumb:
Switch Ign on (do not start engine)
Set Odometer to read total miles.
Press Odometer Button (OB) until CFG1 appears in display
Release the OB.
Pressing the OB briefly will change between CFG1, CFG2, CFG3, CFG1
Once you have selected the CFG (see below).
Press the OB again for 5secs to store the new service frequency.
Turn off the ignition.
I selected CFG1 for my vehicle (05 Reg 2.8JTD), but you must decide yourself for your vehicle, should take 5mins to read this and carry out the resetting procedure
Note: If your vehicle is under warranty and you take it to be serviced by a Fiat dealer they will do this as part of the service.
CFG1 = 30000km (18,600mi) and 365 days in cases of Standard Use for 2.0 petrol and 2.8JTD versions, or in the case of Severe Use for the 2.3JTD versions.
CFG2 = 20000km (12,500mi) and 365 days in case of Standard Use for 2.0JTD versions, or in case of severe use for 2.0 petrol and 2.8JTD versions
CFG3 = 15000km (9,300mi) and 365 days in case of Severe Use for 2.0JTD versions.
Heyupluv
3,862
1,593
France,
touring many years..42+
Is this what you asking for
Step-by-step:
Peugeot 2006
Instructions
Shut off your Peugeot 206's engine and ensure the ignition switch is in the "OFF" position.
Hold the small "Reset" button located below the speedometer gauge.
3
Continue holding the "Reset" button while switching the ignition to the "ON" position.
4
Release the "Reset" button until the "Spanner" indicator light on your instrument cluster turns off. The display screen on your instrument cluster should also read "0" after successfully resetting the service light.
Click on this link and scroll down to Peugeot
http://www.scribd.com/doc/62484156/Service-Light-Reset
wolly
20
ripon n yorkshire
van conversion
40 plus motorhoming and tugin
:cry:
Thanks in advance
Brian.
hi brian switch on the ignition.press the trip button for 10 seconds.press briefly on trip button to select the disired configuration for your vehicle exampel cfg 20 000.miles or 1 year.or cfg 12 000 miles or 1 year.press again for 10 seconds on trip button to memorise the maintenance frequency switch of ignition.hope this helps you.brian
