Spanish telly
Discussion in 'Continental Touring' started by ericonabike, Sep 18, 2013.
  1. ericonabike
    ericonabike Read Only Funster
    Jan 19, 2012
    430
    267
    Leicester
    So, parked up on Cost Brava, thought we'd watch some telly, sad sack Funsters that we are. Plugged telly in, selected Spain, autoscan came back no channels, check aerial connection. Aerial switched on plugged in. Any clues? Something I've missed?
  2. keith
    keith Funster
    Aug 25, 2007
    3,285
    1,670
    Ecclefechan
  3. ericonabike
    Jan 19, 2012
    430
    267
    Leicester
    Freeview. Doing this on phone so sorry if terse!
  4. alan
    alan Funster
    Aug 21, 2008
    541
    490
    skegness / spain
    Spanish TV
    have you set the source to digital?
  5. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,540
    7,821
    Maybe you just have a weak signal..
    It should work no reason why it should not...
    I know, no help at all am I. .......
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,883
    17,542
    YO11 2BD
    are you 100% sure the aerial is pointing EXACTLY at the transmitter mast.
    digital TV is critical on a good signal.....slightly off and screen locks or pixelates....more than slightly off and no signal whatsoever.
    if you have one of those useless flying saucer type aerials, sit back with a good book or watch a DVD.
    you are probably in a weak signal area.
  7. keith
    keith Funster
    Aug 25, 2007
    3,285
    1,670
    Ecclefechan
    You may have to a trial and error approach, scan --- move a bit --- scan move a bit until you get some sort of signal then you may get an idea the direction the signal is coming from.
    We have never got a lot of success with Spain TV ..... can't speak the language anyway. :Rofl1:
  8. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,863
    roche cornwall
    if you have an omni directional ariel and use the english default on your telly you can often get films and programmes in english . usually find some sort of telly in most places .
  9. motorhomer
    motorhomer Read Only Funster
    May 17, 2008
    578
    317
    South Shropshire
    We usually get quite a lot of digital channels in spain, although it does vary depending on where you are.
    Also quite a lot of Spanish TV is dubbed English / American, and the original English soundtrack is often broadcast alongside the Spanish. On my TV - an Avtex, although I am sure others are similar - you can select the soundtrack (the audio button) allowing you to watch English / American TV in spain.
    • Like Like x 1
  10. ericonabike
    Jan 19, 2012
    430
    267
    Leicester
    Cheers all! Have no idea where transmitter is, and lack patience for too much trial and error. It's a Status aeriel BTW
  11. ukbill
    ukbill Funster
    Nov 3, 2011
    4,927
    4,881
    benidorm
    i have never managed to get tv on a status in spain if you get wifi anywhere try filmon for ya tv good luck and have fun
  12. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,506
    3,711
    Lost in La Mancha, Spain
    The Status aerial does work here in spain, but you need a good signal to it before the TV will decode as it's all digital here.
    I striped mine down and found poor connections on the board ( re soldered them ) and used better coax. They also have a "booster/gain" box and many owners do not have the gain turned up ( as high as you can before getting ghosting )
    Hope that helps you as the channels are out there - it's just finding them......
  13. teddybard
    teddybard Read Only Funster
    Aug 21, 2012
    7,610
    8,996
    warwickshire
    Working Fine in Leicester Eric:Rofl1:
Similar Threads
  1. Evadne
    13
    441
