Spanish electricity (1 Viewer)
funflair
19,343
30,216
Guisborough
MORELO palace
since 2012
On a site in Spain with 6amps electric, don't know what the volts are but my suspicion is not a lot at times, it takes the microwave 3 1/2 minutes to do what it does in 2 off the inverter and the fridge on auto keeps going over to 12 volts off the solar or gas, I assume when the volts drop too low for it to recognise it as 240.
andy63
4,672
15,017
south shields
None
since 1990
Hi Martin thought it took the kettle longer to boil over here as well then thought it must just be my imagination.
Ta andy
tonka
10,829
21,525
Cannock, Staffs
A class Burstner 800
Since 2000
With the fridge dropping out I think it's a good indication of low voltage.
A common issue for some when we were over in Morocco, you can get some sort of voltage stabaliser fitted.
funflair
funflair
19,343
30,216
Guisborough
MORELO palace
since 2012
The pole kept tripping so we got the man to check and with 500w water heater plus fridge and battery charger (batteries full) we were pulling 4.8 amps so the volts must have been pretty non existent.
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
I have a plugin tester that can measure the voltage and here in Portugal I've had it as low as 180V, it's supposed to be 220V here.
43,328
49,441
110 volts...
But why didn't he check voltage with his meter?
scotjimland
2,320
10,003
A Woosh bang
Volt drop on Spanish sites is common.. I checked and found at peak times it was less than 200v.. normally it is 220v
so kettles etc will take longer to boil
The law now states 230v +10% -6%, thereby allowing the European 220v system to stay at 220v and UK to stay at 240v, yet both appear to be harmonised!
Badknee
7,407
412,638
notloB
Vantage Neo
Living the dream.
Go and give the donkey that's running the dynamo on a treadmill a kick up the arse to get a few more volts. ;)
Reactions: f6c
43,328
49,441
Agreed Jim, but my calculation said it was 110volts....a 50% reduction.
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
Full sites often suffer volt drop during the day.....
