Sorry...leisure batteries again.
Discussion in 'Motorhome Chat' started by tony_g, Sep 30, 2012.
  1. tony_g
    tony_g Funster
    Aug 29, 2010
    380
    188
    Nuneaton,some of the time
    I currently have one AGM 100Ah leisure battery with a solar panel and controller connected to it. If I want to double up with two batteries side by side do I connect +ve/+ve, -ve/-ve? And what about the solar panel controller connections? +ve to one battery, -ve to the other or both to one battery?
    I know the answer is probably somewhere here but I only have a few years left!
    Thanks :BigGrin::BigGrin::BigGrin:
    [HI]http://www.motts.dsl.pipex.com/second leisiure battery.htm[/HI]
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,700
    17,315
    YO11 2BD
    Hi Tony, yes...pos to pos / neg to neg.
    solar controller goes to one battery only.
    always fit a fuse (30amp should be big enough) to both ends of the pos connecting wire between batteries unless they are so close as to not be vulnerable to cable damage.
    if they are side by side i would still fit one fuse in the pos wire.
  3. hilldweller
    Dec 5, 2008
    26,871
    25,734
    Macclesfield
    You've posted your own answer to half the question.
    The solar just connect + to + and - to - wherever is convenient on the batteries because effectively you have only one big battery.
  4. pappajohn
    Aug 26, 2007
    29,700
    17,315
    YO11 2BD
    :Doh: dont know what i was thinking Brian :Eeek:
  5. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,748
    3,252
    Eastbourne East Sussex
    Just be sure the fuse(s) between batteries are big enough if you run an inverter. A 1.5 kw inverter needs a 150A fuse between the batteries and a 300A fuse in the inverter supply.
  6. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    someone said maybe on here maybe somewhere else about if you connect the batteries together + to + and - to - then connect the load + on one battery and - on the other battery its better for the batteries as the load is spread across both instead of onto one battery.
    something to do with balance although this is supposed to be more effective on larger battery banks.
  7. scotjimland
    Jul 25, 2007
    28,936
    25,589
    that is the correct way :thumb:
    more here , for large battery banks http://www.smartgauge.co.uk/batt_con.html
    • Like Like x 2
