Some more help please for the owner of a 1984 LT31 Camper
Discussion in 'Motorhome Chat' started by colinmud, Jun 14, 2011.
  1. colinmud
    colinmud Read Only Funster
    Jun 4, 2010
    8
    Phew, last time I was put right in about 10 minutes when asking for help in getting my springs sorted. What a brilliant site.
    It's the handbrake that's causing trouble now...
    The sheet metal handbrake has been bent and the ratchet engages only intermittently. Does anyone know where I might obtain a spare, or should I try to straighten out the old one. An expert neighbour has tried once to no avail.
    Once this is sorted I'm back on the road!
    Colin M
  2. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Hi....An expert fabricator will be able to straighten it....
    Any pics please?
  3. colinmud
    Jun 4, 2010
    8
    Thank you
    My wife is away for a week and has the camera so I can't take pictures at the moment. I will remove the brake handle and have a close look at it.
    Thanks for your advice,
    Colin
  4. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Well it's got to be worth a try...
    I've had to get stuff made up / made myself parts that I cannot get hold of any more....
    It can be done...
    Good luck and I hope you get it sorted.:thumb:
  5. Squire
    Squire Read Only Funster
    Dec 30, 2010
    324
    60
    Hi Colin. I've met this problem before and if I'm right I think it'll be because your handbrake was originally designed to be fitted to a LHD chassis. Well, it would be, wouldn't it, being a VW! When it was fitted to a RHD chassis it meant that the mounting bracket is now on the wrong side to resist the 'pull' from the other side than originally intended, thus bending the handbrake lever away from the ratchet every time you 'pull' it on - if you see what I mean. Any competent DIY'er or a half decent mechanic should be able to fix it for you and even add a bit of strength in the right place to prevent it happening again.
