Some help required
Discussion in 'Swift Motorhomes' started by adventure, May 30, 2008.
  1. adventure
    adventure Read Only Funster
    Oct 16, 2007
    131
    somerset
    I am looking for a probable cause to a problem, to help me find the cause I need to see how often the problem occurs, this is where I need some help.
    If you own a 2008 swift motorhome have you had a problem with the electrics "locking up" and not being able to switch anything on, if you have had this problem or one simular please would you post here I would be this happy :Smile::Smile::Smile::Smile::Smile::Smile::Smile::Smile:
    Nick
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,266
    5,251
    East Sussex 01-580-881288
    Hi if you mean the control panel, they have been know to get their software nickers in a twist, disconnect the leisure battery and reconnect tends to cure that, just like a modern TV or PC.
    If not try ringing our Service Manager Glenn, he will know the answer.
    Regards
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,677
    5,833
    Mansfield,Notts
    Hows That ? 7 minutes to get your answer:thumb:
    There not called SWIFT DEALERS for nothing:Rofl1::Rofl1::Rofl1:
    Geo
  4. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,266
    5,251
    Yer not so bad with a spanner either Geo:thumb:
  5. adventure
    Oct 16, 2007
    131
    somerset
    Thankyou for you reply Johns Cross, Yes Geo it is good that they read the forums and reply
    I know that the system locks up on the 07 model, this is common knowledge, swift and sargent say it is not an issue with the 08 model and have only had a very very small amount do it, I am after actual cases by owners of 08 models, I will contact Glenn to see if he knows of any 08 models having this problem, if he does then Swift and sargent would like to know because they are completely in the dark, I have been advised by a major swift dealer that there is a problem, to fix the problem I need to know if it actually is happening to 08 swift owners hence the need for help.
    I do already know of two firms which have eight vehicles with problems but do need some independant comparisons to confirm what the issue may be.
  6. shifter
    shifter Read Only Funster
    Jan 18, 2009
    68
    wee island across pond NI
    I HAVE 05 KONTIKI,IT ALSO BLANKED OUT ONCE.
    UNCLIPT CONTROL PANNEL UNPLUGED WIRE RECONECTED,JOB DONE.
    SHOULD BE HANDYER THAN UNPLUGING BATTERY:thumb:
