soler panel's
Discussion in 'Tech/Mech General' started by Wildbill, Nov 15, 2013.
  1. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,220
    12,589
    goole
    OK now that the engine out the way how do you know if a soler panel is working or not
    there is no fancy amps meters no lights it seems to be a bit of a bodge job who ever done this is a man after my own hart
    all i know is it was on the van when i got it no instructions
    so
    1 can i put my meter on it to find out if it works
    2 if it dose work do i nead any special boxes to hook it up to the battery
    3 or is it best just to rip it out
    4 it is abut 4ftx2ft
  2. davejen
    davejen Funster
    Aug 21, 2008
    1,248
    699
    Kirkpatrick Fleming Dumfries
    hi, bill put a meter set to volts, and connect black to neg and red to pos, you should get a reading, if so its working!, then buy a regulator 10 amps will do off ebay and connect that up as per the instructions and bob should be your uncle.
    hope this helps, you might as well use it, theres probably about £80 to £100 worth in the panel.
    Cheers, Dave:thumb:
  3. SandJ
    SandJ Read Only Funster
    Sep 14, 2007
    1,558
    518
    North Yorks
    Bill I am at the site not far from Askern For the weekend I can show you my set up and show you how to test yours if it helps. Jan is at work tomorrow so no problem popping over.
    Balne Moor Rd, Goole
    :thumb:
    Steve
  4. mick noe
    mick noe Funster
    Apr 14, 2009
    616
    520
    near Boston Lincolnshire
    to steal a line from hagnap...........this is why I love FUN:thumb::thumb:
    • Like Like x 1
  5. hilldweller
    Dec 5, 2008
    26,937
    25,792
    Macclesfield
    You can stick a meter on your leisure battery, off not on hook-up and the battery is 13V or more it's working.
    • Like Like x 1
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,710
    17,328
    YO11 2BD
    assuming the panel is connected to a controller but no leds lit then it appears not to be connected to the battery.
    probably just a blown fuse between controller and battery.
    find the inline fuse, somewhere in the wiring between battery and controller, and replace with a 20amp fuse.
    putting a meter across the panel wires (before the controller) should show around 17v in good sunlight whether its connected or not.
    connect between the controller and battery, if the battery and fuse are connected, should show around 13 to 14.7v.
    i doubt the panel will be knackered, but the controller could be.
    as said.....panel cost could be around £80 and by the dimensions it could be 80 or 100 watts.
  7. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    remember he solar panel is the last thing to connect and must be disconnected first before removing a battery or the controller will be knackered
  8. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,274
    7,935
    West Norfolk
    I don't think normal diagnostic procedures will help with Bill's solar installation.
    The wiring was originally done by a nesting reed warbler. That panel is either connected to nothing or connected to everything!:Eeek:
    Good luck with sorting it all out Bill!:thumb:
  9. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,220
    12,589
    goole
    even fund the nesting reed warbler electrocuted nothing with the wire cuter could not fix that my meter and a snip snip snip could not fix but although it looks a mess it is not as bad as first taught thirst trip out from rebut and every thing working as should for now and battery relocated to locker in back
    • Like Like x 1
  10. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,220
    12,589
    goole
    thanks steve just got your offer we are at MacDonalds goole at the moment how long you there for as a may pop over not had a internet connection for a few days been wild camping :thumb:
    post code?
Similar Threads
  1. Wildbill
    8
    343
