Solar System Upgrade
Discussion in 'Motorhome Chat' started by mr maz, Jun 29, 2016.
  1. mr maz
    mr maz Funster
    Sep 20, 2015
    36
    50
    out there somewhere
    Thanks to advice received from other "Funsters" we have recently upgraded the solar system on our van. Considering how dull the weather has been so far this summer we have been impressed by how much more efficient the system is now.:)
    We thought other might benefit from an account of how we did it.
    Firstly I replaced the dealer installed regulator with one recommended by @Techno, MPP SOLAR PCM-3012. The old regulator never brought the batteries above 13.6v on bulk charge and 13.1v floating, the new one to 14.3v and 13.4v Also I upgraded the cabling to the battery to 4mm2. The final addition inside the van was to instal a Sterling "Auxiliary Battery-Battery Charger/Maintainer" to keep the engine battery charged. This I can't remember who recommended.
    Next, on the roof, I added a 100 watt panel to augment the existing 2x 85 watt panels that the dealer had instaled. I added a blocking diode to the new panel and a diode into the feed from the original panels. 4mm2 cable was used to the regulator from the new panel and from the diode added to the orginal panels. The dealer had glued and screwed the 85 watt panels to the roof (using zinc coated steel wood screws that had rusted,:eek: I replaced them with S/S self tapping screws and plenty of sealant). I decided to leave the original panels well alone as their output voltages and currents were within spec.
    The upshot being that today, even in the rain, we were often getting up to 2.5 amps charging current. (y)Thanks again to all "Funster" who gave advice.
    • Like Like x 7
    • Informative Informative x 1
  2. Bacchus
    Bacchus Banned 1 month
    Jul 27, 2015
    423
    4,286
    Staines
    LoL - I could hardly contain my excitement when I saw the heading, I realised as I was waiting for it to open that you didn't mean the solar system...
    Probably doesn't help that I am just in the middle of a windows 10 upgrade on another PC...
    Interesting though, and thanks for posting, I would love to see some feedback from the return you get in winter months
    • Like Like x 2
  3. Terry and Jan
    Terry and Jan Funster
    Feb 25, 2014
    172
    94
    Saltash,Cornwall
    Well done mate.
    • Like Like x 1
  4. andy63
    andy63 Funster
    Jan 19, 2014
    2,043
    7,693
    south shields
    Hi.. I've been trying to get my head round mixing panels of different wattage. .. I was under the impression that unless the panels have the same voltage rating if connected in parallel, or current if connected in series then the overall available power would be reduced..
    So my question is how exactly have you added the 100w panel and how are the two 85w wired..ie series or parallel. .
    Are the diodes you installed in addition to existing diodes on the back of the panels... assuming there are ...but all the panels I've seen had diodes in a little box on the back...
    Sorry if sounds like an interrogation lol... but these things interest me
    Ta andy
  5. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,132
    15,070
    Leeds the one up North
    My last van had 100+60+40+40 . No problems
    Parallel is the only way, it doesn't matter what each one outputs as long as they're all for 12 volt system or roughly 21.5 volts open circuit
    • Like Like x 1
  6. Techno
    Jul 28, 2010
    14,132
    15,070
    Nice robust unit which makes the £54 easier to accept
    [​IMG]
    • Like Like x 1
  7. Techno
    Jul 28, 2010
    14,132
    15,070
    There may be a minute drop in mppt efficieny if the max output voltage of each is slightly different but it will be repeat minute
    • Like Like x 1
  8. andy63
    andy63 Funster
    Jan 19, 2014
    2,043
    7,693
    south shields
    Cheers Andy. .. was aware that folk did it but the reading I had done made me think the system output would be reduced..
    What would be the purpose of the diodes mentioned in Mr maz post.. I thought panels had blocking diodes installed...
    Andy
  9. Techno
    Jul 28, 2010
    14,132
    15,070
    I haven't fitted any, I only use panels that have twin diodes and the panel cells wired as two halves to reduce shading effect
    [​IMG]
    • Like Like x 1
  10. mr maz
    mr maz Funster
    Sep 20, 2015
    36
    50
    out there somewhere
    Hi @andy63
    Our 3 panels are all connected in parallel and designed for 12 volt systems. Normally the diodes within the panel junction box are what I think are called balancing diode and are required because the panels have 36 cells. Blocking diodes are to stop sunlit panels discharging through any other panel should one become shaded. The regulator, as well as regulating the supply to the batteries, also stops the batteries discharging through the panels at night.
    • Like Like x 1
  11. andy63
    andy63 Funster
    Jan 19, 2014
    2,043
    7,693
    south shields
    Thanks.. I'm getting confused... blocking diodes are just that and prevent battery discharge through the panel...
    Bypass diodes are to allow a system to operate in the event of a panel becoming shaded,or if a panel has a large number of cells they install bypass diodes between the banks to lessen the effect of shade...
    So are the diodes on most panels blocking or bypass... sorry again for all these questions ...:)
  12. Techno
    Jul 28, 2010
    14,132
    15,070
    The only other I know who fits extra diodes is Peter Forbes. If I cover one of three panels I only lose a third of the output and certainly don't lose energy back into the covered unit.
  13. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,863
    roche cornwall
    cant find the right info but my bp solar panels have diodes already on them built in to the box on the back . i,m sure most have them . even my old intersolar that are about 16 yr old came with them as standard .
    • Like Like x 1
  14. Techno
    Jul 28, 2010
    14,132
    15,070
    The diodes in panels are blocking diodes. Bypass diodes are only needed where panels are connected in series
    • Thanks Thanks x 1
  15. andy63
    andy63 Funster
    Jan 19, 2014
    2,043
    7,693
    south shields
    I thought they may install bypass diodes on large panels between banks of cells to lessen shade effect..
    Thanks for the replies and sorry @mr maz for hijacking your thread ..:)
    • Like Like x 1
  16. Techno
    Jul 28, 2010
    14,132
    15,070
    Yes that is correct Andy having re read but you only need bypass diodes between panels if they are in series.
    The regulator has a blocking diode to prevent a return path
    • Thanks Thanks x 1
  17. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,892
    17,553
    YO11 2BD
    Thought for a moment professor Brian Cox had changed something in the universe. :whistle:
    • Funny Funny x 2
    • Like Like x 1
  18. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,863
    roche cornwall
    mind the best panels are those luna panels that you can get . if my memory is right jim had some info a few years ago . luckily we bought the converter diodes and got luna panels working with our solar panels thanks jim.
    • Funny Funny x 1
  19. Steve
    Steve Funster Life Member
    May 8, 2013
    1,570
    1,850
    Compton Berkshire
    Usefull upgrade Mr Maz with the price of the bits now its a good time to go as far as you can with panels and batteries.(y)
    • Like Like x 2
  20. pappajohn
    Aug 26, 2007
    29,892
    17,553
    YO11 2BD
    No good Al....they only work during a full moon with no cloud.
