solar regulator instructions
Discussion in 'Solar Power' started by walburga, Aug 15, 2015.
  1. walburga
    walburga Funster
    Aug 20, 2007
    300
    99
    Leyland
    IMG_20150815_132751.jpg Anyone got instructions for this solar reg ?
    Trying to rig it to control my stand alone 60 watt folding panel, but the battery voltage is going into 15v+ in bright sunlight.
    The light on the left is flashing blue, middle light nothing, and on the right it's amber.
    Got the reg given to me last year.....maybe that's the answer !
    Regards
    Allen
    ps: Also, the button top right appears to be an on / off switch...tried it..nothing changes?
  2. Flamenca
    Flamenca Funster Life Member
    Jun 21, 2013
    792
    485
    West Country and France/Spain
    I would buy a new controller if I were you.
    • Like it Like it x 1
  3. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,190
    3,014
    Kendal, Cumbria
    Looks like it.
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,112
    17,779
    YO11 2BD
    The controller is wired correctly as per photo.
    The 3rd terminals are for dusk to dawn lighting, once the panel stops charging it allows a limited current to flow to a night light or porch light etc without direct battery connection...the button top right controls the light on and off at night.
    4th terminals are for a low powered, usually around 2 amps max, secondary supply...12v cig socket for phone charge etc.
    By your description of lights function its knackered.
    • Like it Like it x 2
  5. schojac
    schojac Read Only Funster
    Apr 25, 2009
    339
    234
    Cambridgeshire
    I have a similar one and it's important in what order things are connected. If memory serves me right, as I can't find original instructions, you need to connect the supply from the panels last otherwise it displays a fault light.
  6. schojac
    Apr 25, 2009
    339
    234
    Cambridgeshire
    This is my regulator (EBAY item No 331490150750, has worked faultlessly for 5 years. Not bad for under a tenner :)
