Kool Kroozer
- Apr 19, 2014
- 1,361
- 2,228
- Low Profile Hobby Premium
- Always learning
Well i have fitted my x2 panels along with the solar charger and all is working fine, i have wired it up as you would expect, + & - leads from the panels to the + & - terminals to the solar charger, then + & - from leisure battery to the + & - on the solar charger, now as you know most if not all solar chargers have another connection for "Load" again + & - connections, i have no reason to connect anything to these ,However (please try to keep up) on the system that was fitted by Spinney Motorhomes on our previous van it had all the same connections ( Solar Battery Load ) the Solar + & - went to the appropriate connections on the controller but the leisure battery connections were different, the positive battery was connected to the positive of the Load and the negative battery connection was connected to the negative battery, even though it worked fine and we never had any problems with it i only noticed it was connected this way when we were about to sell it, i actually took a couple of pictures of it as i found it to be a strange connection.... why would it be connected up like this ? or is this normal ?
