Solar problems help! (1 Viewer)
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
I have a 120w solar panel feeding 2 x 110 amp batteries and also engine battery. For some reason the regulator doesn't seem to cut off the supply to the batteries and it doesn't seem to get a charge to the engine batteries. My batteries are continually bubbling during daylight.
When i pull the fuse and use the onboard charger all is well.
The system is new, dealer fitted, and i have had the controller replaced but it's still the same.
Any thoughts?
andy63
4,672
15,017
south shields
None
since 1990
Hi Bobby. . Is your comtroler a dual output designed to charge two battery banks... or have the leads just been extended to incorporate the vehicle battery as well..
If that's the case could that arrangement be confusing the controller so to speak...
Only a thought!!
Andy
Bobby22
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Hello Andy, the solar panel is fitted into the van's distribution unit, it is meant to supply the battery bank then top up the engine battery. As i'm lead to believe.
The controller is single 10 amp pwn.
Bobby22
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Golden rule of regulators: 1 Connect battery so it works out 12 or 24V 2 Connect panels.
So I wonder if you have managed to get it in 24V mode.
Thanks Brian,
I fitted second controller myself 'by he book' . I wonder if the controller is set too high (factory set) and my batteries never actually reach this factory setting
What should be the reading for a fully charged battery?
I get 14.6 when on solar........13.9 immediately after disconnecting the panel.
andy63
4,672
15,017
south shields
None
since 1990
Ahh not a clue then.. not that I had anyway:LOL:
But sounds like it should be a dealer problem...
Brian suggestion seems possible but you would think the installer would be aware of that...
Andy
Bobby22
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Andy
Andy do you subscribe to the idea that the batteries are not reaching the controllers' parameters so carry on pumping in more?
andy63
4,672
15,017
south shields
None
since 1990
Well it sounds like it if the batteries are boiling all the time...
Are you having to top up the water..
The voltage of 14.6 should drop when the batteries are fully charged..
I'd be checking the voltages and current flow with a multimeter.
What I'm not sure about is the fact that your controller feeds the van power management panel which must then decide when the batteries are full and to distribute a charge to vehicle battery... so it seems you have more than just the solar controler to consider...
Again just my thoughts as I have never put panels through the vans built in system... so is it the controller or the van pmp that's not right..
Andy.
DBK
18,019
48,071
Plympton, Devon
PVC, Murvi Morocco
Thanks Brian,
After it has had time to settle down it should read around 12.6 volts or a little bit more. The voltage immediately after charging is not a reliable indication.
Bobby22
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
I have taken a reading after about an hour and the batteris read around 13.2 so it would probably go back to the figures you mention.
tonka
10,829
21,524
Cannock, Staffs
A class Burstner 800
Since 2000
What van ?? and what is the fitted system thats already in place..
andy63
4,672
15,017
south shields
None
since 1990
Put a resonable load on the batteries for a few minutes and they should recover to 12.7v when you remove the load and without the panel connected... but if panels are connected the voltage should drop to say 13.4 v when the batteries are charged with a minimal current flow if there is no load on them say 200 to 400 milli amps.. the float voltage will depend on what type of batteries the charging system is configured for... ie wet cell gel etc
Andy
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
That looks normal. Our regulator keeps cycling 14.6 - 13.9 ish continually. In other words, a quick squirt of power then off. Which I don't like but the battery seems OK.
I have no idea how the two batteries are linked, there are a few ways. So no comment.
Anyway, it's new, get them to sort it to your satisfaction.
Derbyshire wanderer
1,288
2,385
Derbyshire
C class
15 years
Any thoughts?
Is the bubbling gentle or furious with a smell to it?
It sounds to me that the charge controller is possibly giving a slightly higher output than needed causing the batteries to gas a little. If there is no known brand name on it, it could be some mass produced Chinese unit that has never been calibrated at manufacture.
Personally I would replace it with a Victron mppt controller as you will get the best charging regime from that available solar.
Bobby22
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Andy
Running all electical accessories now.
tonka
10,829
21,524
Cannock, Staffs
Since 2000
Rapido 680ff, Distribution DS 300-RA
Ok... Sorry cant help on that one..
I asked just in case was an Autotrail and they have their own built in solar regulator and smart charging..
Might have been a clash between a seperate regulator and the built in one..
Good luck with it..
Bobby22
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Andy
Ok... Sorry cant help on that one..i
Good luck with it..
I'm not sure that the distribution unit is controlling the solar, there is a dedicated fuse in the distribution panel for " solar regulator which is connected directly to the hab battery.
Thanks Bobby
andy63
4,672
15,017
south shields
None
since 1990
Thanks Bobby
If you are charging both leisure and vehicle battery off the solar then something has to decide when to start charging the vehicle battery.. so I suspect the van pmp must be involved somewhere..and you indicate you don't think that is happening... so I'm still thinking you have more than just the solar controller to consider..
Andy
Bobby22
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Andy
Hi Andy, batteries are recovering fine. To put you in the picture, since i got the van i had been on rally fields no problems solar great. When i parked up at home i left it for four days. I checked the levels on the internal control panel. The leisure batteries were fully charged with a slight drop on the engine battery.
I plugged into 230v in the garage and switched on charger. All fully charged next day.
That is when i noticed my batteries were bubbling.
So disconnected solar and it stopped (still on 230v charge)
Fully charged on ehu no probs if i disconnect the 230 v and leave to charge on solar i get constant bubbling until dark oclock.
I spoke to the dealer's auto electrician and he suspected dodgy solar controller, so sent me a new one. I fitted it and have exactly the same bubbling and no charge to the vehicle it seems.
I asked the AE if the solar was through the distribution unit and does it supply vehicle battery and he replied it was and did.
I don't want to stew the batteries, and hope to resolve without having to drive 400 round trip to dealer.
Edit, there is only one wire ,to each terminal, going into the battery bank.
Thanks Bobby
andy63
4,672
15,017
south shields
None
since 1990
Thanks Bobby
Well it does sound like your solar charging set ip is capable of overcharging your batteries..
Maybe try and find out what the current flow is ... mine will show from 0 current to maybe 400ma when the batteries are in a good state of charge with no load..
The batteries can only be charging if the voltage is too high from the solar controller which is what you said at the start,but cant help thinking you would have to have been really unlucky to have had two duff controllers...
Batteries will bubble slightly anyway.. but wouldn't want to see lively bubbling on what we're already fully charged batteries...
Hope you get it resolved to your satisfaction...
Andy..
Bobby22
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
Andy..
Hi Andy, i'm beginning to think the solar controller is wired into the system wrongly.
There is a 20A dedicated fuse for the controller in the distribution box, but there is no wire coming/going from this terminal and if i take the fuse out it makes no difference.
I noticed @Techno had similar problems when he bought his rapido.
From the darkside...lol
I suspect that if it isn't going through the distribution unit properly it will not be collecting proper feedback and won't be able to send an in parallel charge to both hab and engine.
I shall get on to dealer spark in the morning with my deductions.
Thanks again for all replies
Aug 6, 2013
11,953
16,568
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
If it helps my mttp controller holds the charge voltage at 14.5v for two hours then drops to 13.8v from then on. I've noticed gassing on occasion because after being on hook-up for some time the batteries are fully charged and as soon as I'm off EHU a small current draw from the domestic equipment instigates a full sequence from the solar system. It's obviously an unnecessary boost at that point but appears to cause no harm. I top up at the end of each season & haven't noticed any excessive loss of electrolyte.
Unless a complete system, including solar, from one manufacturer is installed then smart chargers are going to operate independently of one another and won't always function quite as intended. As I said it doesn't seem to cause any harm. Many more batteries are damaged by never receiving a full charge than are damaged by 'over-charging'.
