Solar power
Discussion in 'The Beginner' started by tan, Jul 3, 2010.
  1. tan
    tan Read Only Funster
    Nov 17, 2009
    66
    Braintree. Essex
    I am thinking of buying and installing myself a 80w solar panel but am unsure how to do it properly. I have two 100amph batteries which charge off the onboard charger and the alternator via split charger but the starter battery only charges off the alternator so I have the following questions:
    1 how do i phisically connect the solar panel to the regulator/controller and the leasure batteries
    2 can I connect starter battery to the solar panel system as well and if so how
    please keep it simple and pictures / diagrams will help
    thanks in advance
    terry
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
    panel to reg...no probs, it will be in the fitting instructions for the regulator.
    reg to batteries....either direct to the batteries or, as i did, connect to the onboard chargers 12v output terminals.
    engine battery.....easiest way is a three pole switch (on/common live/on) between the reg and both batteries....one side to engine battery and one to leisure batteries and input power from reg to the center....simply switch between engine and leisure... means more wiring to the engine battery though.
