solar power for cab battery
Discussion in 'Solar Power' started by shakeytits, Jul 9, 2014.
  1. shakeytits
    shakeytits Read Only Funster
    Jan 17, 2014
    13
    10
    west yorkshire
    hi all, just a quick one , whist in storage { outside } the vehicle battery tends to drain after a period of time , like most cars I suppose, al im after is a portable solar panel to keep it topped up so it starts when I come to use it, anyone recommend one please , and what size would I need, my vehicle is a 2009 autotrail 700se 3.ol , thanks
  2. wivvy's dad
    wivvy's dad Read Only Funster
    Jun 22, 2010
    3,218
    1,807
    48.066895,12.862673
    • Like it Like it x 1
  3. Yorick
    Yorick Funster
    Oct 1, 2013
    4,109
    6,031
    Lanzarote
    So if that is 13 watts does that mean it will fill a 90w leisure battery in 7 hours?
  4. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    Don't go for more than about 15W, or you'll need a regulator to avoid over-charging. Alternatively, if you have proper solar for your hab battery, you can get a device that trickles the engine battery from the hab one. An even cheaper solution (which I sometimes use) is a simple fused lead with croc clips both ends that I merge the hab and engine batteries together so both get the solar. More typically, though, I isolate the engine battery. It easily lasts over winter with no drain on it.
  5. cmcardle75
    Jun 8, 2012
    670
    263
    Reading
    Only in direct sunlight somewhat nearer the equator. Of course, a 90WHr battery is actually a 7.5AHr battery, which is a size more usual for battery backup in alarm systems. A 110AHr leisure battery (i.e. 1.32KWHr) would take about 100 hours of direct sunlight. In reality that would be about 3 weeks in a UK summer.
  6. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    Over winter even an 80W solar panel only has about half an amp (if you are lucky) output because the sun is so low in the sky so around 6W effective power. It all depends what devices you have draining your battery, alarm and radio on standby will eat a fair bit. Other than that the amount of self discharge will depend on the age/condition of the battery. Never had a problem with mine. Regular checks to make sure your battery is not overcharging and gassing is a good idea whatever system you fit.
    • Like it Like it x 2
  7. Yorick
    Yorick Funster
    Oct 1, 2013
    4,109
    6,031
    Lanzarote
    Can you tell I know bugger all about leccy?
    :BigGrin:
  8. hilldweller
    Dec 5, 2008
    27,709
    26,809
    Macclesfield
  9. Tessntim
    Tessntim Read Only Funster
    Jun 22, 2014
    62
    8
    Devon
    My sister just bought a fiatDucati granduca it has a solar panel on roof but she can't find the inside battery all lights ect work does any one know Whare it is looked bit can't see it would it mean the cab battery is running the 12v ? We baffled
  10. timdownieuk
    timdownieuk Funster
    Apr 9, 2013
    619
    330
    Ayr
    Has she looked under the cab seats? Often one squeezed in there.
  11. g8ysn
    g8ysn Funster
    Jun 5, 2012
    589
    404
    ng219ep
    gave mine 2 my brother 2 keep his vehicle charged whilst away in greece, going away present
