Solar Panels (1 Viewer)
scotjimland
2,309
9,979
A Woosh bang
Hi Betty
They are not difficult to fit but much depends on the DIYers skills..
If they feel confident about sizing and running cables and fitting a charge controller then it's straight forward.. if however the last sentence was double Dutch then I would leave it to a professional ..
Jim
43,323
49,428
as jim said, not difficult but you do need the confidence to drill a hole through the roof in exactly the right place.
mounted mine above the wardrobe and brought the wires through and into the w/robe. fitted the controller at the top of the w/robe wall and ran wires down to charger/power supply which is in the bottom of the w/robe.
use a good quality sealer under the panel mounting brackets and the cable entry hole and all should be well.
C.L.S
Trader - Service & Repairs
Jul 22, 2007
438
60
Not long enough
To simplify glue solar panel to the roof using Sikaflex bringing a 2 core cable through the roof using a weather proof gland bedded again with Sikaflex , connect the wire to the regulator marked with a pic of a solar panel , bring a cable feed from the leisure battery to the regulator connected to the battery pic . HEY PRESTO :roflmto: Make sure you use a decent size cable , minimum 2.5mm
Mark
