Solar panel
Discussion in 'Motorhome Chat' started by Theresa100, Jun 25, 2014.
  1. Theresa100
    Theresa100 Read Only Funster
    Aug 23, 2013
    16
    6
    Eton
    Please can some one advise ,if you have a solar panel and two leisure batteries which battery should you connect pannel too the one that's was already fitted with van or the one you had added many thanks theresa
  2. hilldweller
    Dec 5, 2008
    27,771
    26,862
    Macclesfield
    Both leisure batteries should be linked together so it does not matter.
    • Like it Like it x 1
  3. Baycott
    Baycott Funster
    Nov 6, 2013
    6,489
    13,720
    East Sussex
    As they are probably wired in Parallel I don't think it matters.
    Others with more knowledge will be along shortly to confirm :thumb:eek:r not:Doh:
  4. Bobby22
    Bobby22 Funster
    Dec 15, 2013
    1,166
    4,166
    Scotland
    Useful video may help?
    [ame="http://www.youtube.com/watch?v=bfvLcTxgvzo"]Charging Two 12V Batteries in Parallel | NOCO Genius® - YouTube[/ame]
  5. Theresa100
    Aug 23, 2013
    16
    6
    Eton
    Thanks everybody for your help :Smile:
  6. hilldweller
    Dec 5, 2008
    27,771
    26,862
    Macclesfield
    Not bad apart from the graphics with the squeakie voice person being incorrect at 1min in. In both cases the two batteries remained connected together so the batteries could not be charged separately, not that you would if using a pair.
  7. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,301
    3,104
    Kendal, Cumbria
    As he ^^ says :BigGrin:
  8. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,680
    14,538
    North Lincolnshire
    So:
    Would a 95ah and a 110ah connected in parallel be seen by a charger / solar etc. as a single 205ah battery, or will it charge to the 95ah level?
  9. hilldweller
    Dec 5, 2008
    27,771
    26,862
    Macclesfield
    If they are the same construction, like both wet, I think so.
    If you were to make a 205Ah battery all you would do is put the same area of lead as those two in a single container.
    You won't do damage wiring them together, fused. Charge them up and see what the result it.
    So, charge up the 110Ah, load it up and see how long it runs. Charge the 110Ah and 90Ah separately, wire them together, charge again together ( obviously this will be a short burst ) then apply the same load. If you get nearly double you know it's worked.
    Charge again together ( long time now ) and repeat the load test to be sure.
    Naturally keep you eye on them while testing, just in case.
  10. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,301
    3,104
    Kendal, Cumbria
    The more simple answer is that they will definitely be seen as the sum of the two Ah capacities. The batteries need to of the same construction because the charger will need to be the correct type (unless it can be switched) for either lead acid or gel. A fuse in the +ve link wire between the batteries is often advised in case one battery fails catastrophically and effectively short-circuits its partner (not a common occurrence :Smile:). If fitted the fuse should be slightly higher rated than the main supply fuse to the MH electrics.
  11. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,268
    17,931
    YO11 2BD
    in addition, if there is the slightest possibily of the link wire being damaged then fit a fuse at BOTH ends of the live/pos wire.
    If one fuse is fitted and the link wire becomes earthed the fuse will blow BUT the other battery without a fuse is still shorted to earth....result, a fire or an exploding battery.
  12. ukbill
    ukbill Funster Life Member
    Nov 3, 2011
    4,999
    4,920
    benidorm
    i have now got 2 batteries both 110ah i have fitted the solar panel to 1 taking the live and the other taking the neutral ?
  13. outkast
    outkast Read Only Funster
    Jan 7, 2014
    202
    205
    potters bar
    you can get solar panel controllers with outputs for two batteries.
  14. ukbill
    Nov 3, 2011
    4,999
    4,920
    benidorm
    thats ok i dont need it i have all mine fitted now and its working a treat thanks to peter (Peter and Elaine )
    for the control box and thankless to techno for the relay info and anyone else who's knowledge i used
  15. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,297
    3,741
    walthamstow east london
    all lead acid batteries are made up of 2v cells so however many you link up the charger will see that ampage
