solar panel
Discussion in 'Motorhome Chat' started by stephen harwood, Mar 1, 2015.
  1. stephen harwood
    stephen harwood Funster
    Nov 2, 2014
    549
    387
    bridgwater
    Hi what sort of cost am I looking at to run 2x110 amp batteries by solar panel regards steve
  2. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,434
    7,723
    The question does not really make sense...
    A solar panel will produce whatever it can depending on weather and it's output design. The batteries will store whatever they can until they are full..
    First thing is see what roof space you have available, then depending on the size of your wallet fit what you can afford or want to spend..
    I have just bought a 120w panel for £82... My Autotrail has a built in solar regulator that will take 120w, so an easy match.. Have 2x 110amp batts fitted...
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,693
    17,303
    YO11 2BD
    To charge purely by solar......not worth it, you can't rely on the sun shining or for how long.
    You really need another charge source as well.
  4. stephen harwood
    Nov 2, 2014
    549
    387
    bridgwater
  5. tonka
    Jul 2, 2008
    5,434
    7,723
    @stephen harwood what motorhome do you have ???
    As I mentioned above some have built in regulators so you could add a first panel at quite reasonable cost...
  6. pappajohn
    Aug 26, 2007
    29,693
    17,303
    YO11 2BD
    As a guide....
    Batteries £100 each.
    Solar panel £80 > £100
    Regulator £30
    Labour...who can say
    • Like Like x 1
  7. stephen harwood
    Nov 2, 2014
    549
    387
    bridgwater
    Bessacar e745 just bought 2 new batteries thanks
  8. stephen harwood
    Nov 2, 2014
    549
    387
    bridgwater
    Thanks john
  9. Drexxer
    Drexxer Funster
    Oct 26, 2014
    257
    281
    Lincolnshire
    Hi, if you don't mind me asking what make / size is the panel as I'm thinking of upgrading mine
    Andy
  10. pappajohn
    Aug 26, 2007
    29,693
    17,303
    YO11 2BD
  11. tonka
    Jul 2, 2008
    5,434
    7,723
    This is the one, I put an offer of £82 and it was accepted straight away. Only came the other day so not fitted / tested yet.
    I only noticed after the buy button that its a "poly crystal" where as in the past I have always bought "Mono". In reality I dont think there will be much difference, both types have their pro's and Con's.
    http://www.ebay.co.uk/itm/NEW-120W-...968?pt=LH_DefaultDomain_3&hash=item41915ff030
    • Like Like x 1
  12. pappajohn
    Aug 26, 2007
    29,693
    17,303
    YO11 2BD
    Polychrystalline is about 70% of the efficiency of monochrystalline.
    I believe poly is a man made chrystal whereas mono is a natural chrystal.
    • Like Like x 1
  13. stephen harwood
    Nov 2, 2014
    549
    387
    bridgwater
    Thanks tonka
  14. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,615
    2,189
    Rutland
    In my experience not true ,I have 180 watts on my roof and 2 110 amp batteries ,I have led lights and a 12 v tv and games machine I also charge my phones and tablets via 12 v leads.
    When you drive to your destination your putting charge in and unless your a heavy power user the above set up will be more than enough for a leisure camper .It. would not however suit long camping off grid in the middle of winter,in summer you'd never come near to running low.
    As far as costs goes you can get a couple of panels and a regulator off ebay with all the bits and bobs for under £200 .It is an easy DIY job however if your not sure for a case of beer I'm sure you could tempt a handy Funster to help you
    Vlad
    • Like Like x 2
  15. pappajohn
    Aug 26, 2007
    29,693
    17,303
    YO11 2BD
    And if the sun doesn't shine for 4 or 5 days.....not unusual in the UK.
    I would still want a backup charge source or I could be sat in the dark.
    • Like Like x 1
  16. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    5,579
    11,470
    Kettering
    Ours seems to cope OK. We have 200W and 2x110ah. This winter we've been off grid a lot and never had any problems.
    • Like Like x 1
  17. Vlad The Impaler
    Apr 22, 2012
    1,615
    2,189
    Rutland
    Pappajohn A man of your experience should know that two good 110 amp batteries could last 4 or 5 days or longer without any input from solar.
    Also the sun doesn't have to be out 24 /7 We camp in Scotland in the summer and may not see the sun for a good few days but always have full charge by mid morning!
    Vlad
    • Like Like x 1
  18. stephen harwood
    Nov 2, 2014
    549
    387
    bridgwater
    Would gladly buy crate of beer any offers?
    • Like Like x 2
  19. tonka
    Jul 2, 2008
    5,434
    7,723
    Steve, there is plenty of info already in the solar section about DIY fitting...
    You can even ask here as you go along... If you can use a drill, apply sealant and connect a few wires you are sorted..
    Using the drill through your roof for the first time is the killer !!!!!!!!!!!!!!!!! o_O
    • Like Like x 1
  20. stephen harwood
    Nov 2, 2014
    549
    387
    bridgwater
    Thanks mate
