Solar panel wire
Discussion in 'Solar Power' started by Manic, Mar 25, 2014.
  1. Manic
    Manic Funster
    Nov 4, 2011
    1,082
    1,195
    Uk
    I'm changing my regulator and the position of it, it was just under panel with a run approx 6/7 metre to the battery. With the new regulator (Schaudt LR1218) going straight to the Schaudt ELB, about 5.5 metre run, so where is the best place to buy 4mm2 cable from, twin or single.
  2. Phill D
    Phill D Read Only Funster
    Dec 6, 2011
    4,414
    4,633
    South Wales
  3. scotjimland
    Jul 25, 2007
    28,975
    25,674
    Buy the proper cable from here.. http://www.shop.solar-wind.co.uk/acatalog/cable_ho7rnf_rubber.html
    and while you are on the site, check your cable size !
    http://www.solar-wind.co.uk/cable-sizing-DC-cables.html
    You don't say what size panel you have but as an example..
    A 100watt panel with a 6mt run and 2% loss requires 6mm2
  4. Manic
    Manic Funster
    Nov 4, 2011
    1,082
    1,195
    Uk
    Thanks for links, as for the panel, I don't know what wattage it is as it was already on the motorhome but the wire that goes from regulator to battery is small maybe measuring about 1mm across!! It has been ok keeping the battery's up but I now want to charge engine battery as well, hence the change.
  5. scotjimland
    Jul 25, 2007
    28,975
    25,674
    fair enough..
    the reason for sizing correctly isn't for the current carrying capacity, 4 mm will carry 30A, way more than you need.. .. but when it's a low voltage system it is to keep the losses to a minimum..
    anyway.. best of luck with the rewire.. keep the site for future calcs..
