Solar Panel - how many watts is it? (1 Viewer)
RowleyBirkinQC
2,347
226,505
Dazed & Confused
Apologies if this is a silly question due to my ignorance! The van we bought second hand last autumn came with a solar panel already installed. I'm contemplating whether we should fit a second solar panel in case we do more wild camping / stay at sites without EHU etc.
With this in mind, is there a way to easily identify the wattage of the existing panel? Would the wattage of the existing panel in anyway influence or dictate which second panel should or could be installed?
Thanks in advance for any pointers!
Nov 6, 2013
3,201
229,291
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
No question is silly on here. There is usually someone else that would like to know the answer but hasn't got round to asking.
That's me so I will be following this thread with interest. (y)
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Regardless of the wattage of your existing panel, it has no bearing on the wattage of any other panel you add. Add whatever you like.
The size of the panel will give a good idea of the wattage.
Jan 29, 2014
1,317
975
Scunthorpe
Autotrail Apache
July 2013
Do not agree with the above as if its 100w pannel and you add another 100w it can over load say a sargent system which states 120w max.
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
If you have a small inspection mirror, try to look on underside of panel, there is often a spec label stuck there. Usually just below terminal box. Just read it in reverse, you'll either have WOOl, WOB or WOd ish haha. (y)
Emmit
8,032
17,747
Cornwall
Pilote Explorateur
Jan.2014
And as Laurieash alluded to, we need to know the size of the regulator, (small box that has connections from the existing panel to the batteries.) Should have the 'ampage' written on it.
Sorry in advance for dumbing down my comments but I/We don't know your knowledge.
Jul 2, 2011
953
492
UK
Swift Kon Tiki Tag, 2007.
Newbie
Hope OP does not mind me butting in. I am in exactly the same situation, existing panel is 120cm x 32cm. Pic of the regulator below.
Lenny HB
53,407
149,864
On the coast in West Sussex
Hymer B678 DL
Not a very common size but by surface area I would guess at around 50 watts, also depends on type for a given output a Polycrystallinewill be larger than a Monocrystalline panel.
Jul 2, 2011
953
492
UK
Newbie
Thanks, so not very big then.
Can a second panel be fitted (plenty of roof space) and fed into the same regulator?
If it can, what would be a good size to go for and where from?
I have been quoted ÂŁ75 (3 hours labour) just to fit, does that sound about right?
Lenny HB
53,407
149,864
Hymer B678 DL
Are you sure your sizes are right 120x32 is 47" x 12½".
Labour rate sounds cheap most dealers charge at least £40 hour, I would expect them to couple the cables with MC4 connectors on the roof so shouldn't take that long, 1 - 1½ hours.
Your regulator is only 6.5 amps so you would need a new regulator, in bright sunlight a 100W panel can get up to 5.5 amps approx.
eddie
8,146
41,215
Taunton Somerset
RV
since 1989
You will need to ensure that the wire from the regulator to the leisure batteries is also up to the job, otherwise your wasting your money on the additional panel.
A good analogy is always water! Imagine a the biggest supermarket that you have ever been in!
Now imagine the surface area of the roof!
Now imagine that the roof is slightly sloped to the middle
Now imagine that it is raining, heavily!
Now imagine that there is a massive drain pipe in the middle of the sloping roof to take all of the water
Now imagine the diameter that pipe would need to be to handle that amount of water
Now imagine, instead of that huge pipe, replacing it with the down pipe on your house or bungalow :Eeek:
It would work, but not very well!
And that is why cable length and diameter are inportant.
Lenny HB
53,407
149,864
Hymer B678 DL
Ref: to Eddies comment about cable looking at your photo, whoever installed your panel looks like the have used 1.25 or 1.5 mm sq mains cable, that would need replacing with at least 4 mm sq. cable.
Jul 2, 2011
953
492
UK
Newbie
Thanks, so clearly going to be more expensive than it might have been.
can anyone give me a idea of a good regulator.
funflair
19,333
30,176
Guisborough
MORELO palace
since 2012
Might as well get a new regulator to take how ever many panels you want, fit a MPPT and get 25 to 30 % more power, I did a test with two systems wired and the old sunsaver was 25 or 30% behind my new Votronic MPPT, changed it to another Votronic MPPT and now they match each other amp for amp.
Votronic told me if the panels are different put them on a separate controller.
Jul 2, 2011
953
492
UK
Newbie
Does this mean leaving the panel and regulator I already have and adding a new regulator for the new panel? I assume both regulators can then feed the same leisure batteries?
Lenny HB
53,407
149,864
Hymer B678 DL
Better to replace the regulator, output of two regulators coupled togther will cause problems. Also has the added advantage you only need to run one set of cables down from the roof.
Mar 26, 2009
8,162
11,220
Yr Wyddgrug
Hymer B678DL
Since 2009
Broken Link Removed what I use. Very happy with its performance (100+50 watt solar panels).
This would replace your existing controller and allow another panel (or two).
RowleyBirkinQC
RowleyBirkinQC
2,347
226,505
Dazed & Confused
This is interesting, I will have to have a gander at my panel and associated components - the only thing I know (if I recall correctly) I have is a "Fox-D1" box which shows voltage/amps on LCD display. does anyone know if this is the regulator or whether it just hooks into a regulator to show what is going on?
RowleyBirkinQC
RowleyBirkinQC
2,347
226,505
Dazed & Confused
After looking through the folder full of papers which came with the van, assuming nothing has since changed, it seems we have a 90w solar panel onboard which was fitted by Solar Solutions in Poole. This is feeding 2 x 100A leasure batteries with a batterymate topping up the vehicle battery. I may see how we get on when not on EHU before changing it.
Guess I really should have looked there first before spawning this thread asking for guidance! :rolleyes:
Thanks for all your input though, I found it very useful. :)
Peter A Forbes
270
184
Rushden, Northants, UK
Mercedes 614D
With a 90 watt panel you will be fine from May through to September .
It really depends where you are.
Panel ratings are absolute maximum which you will not get in the UK, even in summer. We have 160W panels and found that it all depended on our 12V consumption the day before. A good day would see the batteries right up, but a heavy day and clouds meant that they weren't. Three days of thunderstorms in Carpentras last year saw us getting the EHU cable out.
The Mercedes will have 4 X 100W panels and twin controllers as we are going to run longer without EHU this year.
We are fairly power-hungry with lights (LED) laptop charger, TV/Sat receiver etc etc.
Peter
