Solar panel connection types?
Discussion in 'Motorhome Chat' started by monty the motorhome, Mar 30, 2014.
  1. monty the motorhome
    monty the motorhome Read Only Funster
    Jan 27, 2013
    32
    9
    Harrogate
    Just got a 60w Solrtroncia solar panel which connects to the battery via crocodile clips.
    Now I would like to have to two options of connecting :-
    1. As i do now when placing the panel outside just connecting to the battery via the croc clips or may be as in number 2 by having a seperate connector in the battery box and use a push type fit conenctor.
    2. Putting the solar panel in the motorhome by a window when in storage and connecting to the battery via a push type fit connector which i would then drill a hole through the battery box and hard wire to the battery.
    My problem is this, where can i get and what type of connectors do i need?
    Paul
  2. daveandsan
    daveandsan Funster
    Dec 10, 2013
    1,429
    2,011
    South Staffs
  3. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,229
    14,216
    Bolsover, Derbyshire
    I am not at all technical, but some years ago connected a solar panel directly to my leisure battery while in France
    Fine till it went dark I had no 12V, solar panel without a regulator had killed my battery
    Be careful :thumb:
  4. andyman
    andyman Funster
    Sep 23, 2007
    1,164
    520
    Leicestershire
    Quick and cheap option is a 10 amp connector like you get on a mower or strimmer.
  5. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,301
    3,104
    Kendal, Cumbria
    If you already have either a cigar lighter socket, caravan-type 2-pin, or Hella connector already installed and running off the leisure battery simply plug it into that.
  6. sadlonelygit
    sadlonelygit Read Only Funster
    Jan 28, 2014
    155
    95
    forest of dean
    to do the job properly you need a diode protected charge controller which won't allow too much juice into the battery, but tbh a 60w isn't much (5a/hr max)
    however current flows both ways without a diode and your battery will happily flatten itself at night.:Rofl1:
