Solar panel and leisure battery purchase
Discussion in 'Motorhome Chat' started by Sift, Apr 28, 2014.
  1. Sift
    Sift Read Only Funster
    Mar 30, 2014
    101
    63
    Ringwood, UK
    Hello all. As suspected, the solar panel isn't supplying any power and the leisure battery is now in a sorry state (presumably due to lack of use and hence no charging of any kind).
    I need to stump up for a new panel and battery. Before I go to the nice motorhome dealers near me, is anyone aware of any deals or discounts available for cost comparison purposes please?
    Regards,
    Lee.
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,706
    17,323
    YO11 2BD
    before splashing out....have you checked the voltage with a multimeter or just relying on the controllers led ?
    Could just be the controller thats not working.
    The wires on the Panel side of controller (red and black on the left of the controller) will be around 17v/18v
    Battery side of the controller should be around 13.6v in sunshine
  3. Sift
    Mar 30, 2014
    101
    63
    Ringwood, UK
    Cheers Pappa. Unfortunately I have used a multimeter to confirm.
  4. pappajohn
    Aug 26, 2007
    29,706
    17,323
    YO11 2BD
    fair enough....thought i would mention it before spending big bucks :thumb:
    • Like Like x 1
  5. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    be sure to disconnect the solar before removing the battery or you could goose the controller. Chances are a dead battery may have cooked it already.
  6. Moodybrook
    Moodybrook Funster
    Jul 7, 2013
    769
    634
    Dumfries
    Solar
    I got my stuff from these, not the battery, there are many threads on batteries here. Do a search.
    http://www.bimblesolar.com/
  7. Wickolad
    Wickolad Funster
    Sep 10, 2013
    480
    518
    Wickersley
    Hi Sift, I know you've said you have confirmed with a multimeter and don't want to appear condescending in any way. Did you test at the panels waterproof junction box at all? Should be about 41v open circuit I believe. I only ask this as there is usually a diode in there and the leads are soldered to the circuit board, always worth a check to ensure the solder connection isn't broken due to vibration, or a broken cable/connection between the panel and controller. Only a thought but worth a check if you've only tested at controller end of circuit. Again, sorry if you've already done this, it's just, I'd hate to have to splash out for anything twice.
    Lance
    • Like Like x 2
  8. Sift
    Mar 30, 2014
    101
    63
    Ringwood, UK
  9. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    Realistically you don't want to be paying much more than £1 per watt for a solar panel.
    I just got a 140 watt panel for £149.00 which I think is about the right price.
    • Like Like x 1
