Solar Output Controller....What do you connect to yours? (1 Viewer)
Baggers53
187
221
Stafford
From most Solar Panel controllers there are two sets of output terminals.
One for the leisure battery, and one for an additional load....What do you connect
to these terminals.
I have a device that has 3 car cigarette charger sockets and a USB port charger.
So as we drive along or parked up on site a number of different devices can be
charged from "free" solar power.
DBK
18,009
48,004
Plympton, Devon
PVC, Murvi Morocco
I dont use them, all the power goes to the batteries and chargers etc are taken off them. I don't think the power from the load terminals is any more "free" than the power going to and from the batteries and the battery voltage will be a more reliable source - it will still be there in tunnels! :)
funflair
19,303
30,068
Guisborough
MORELO palace
since 2012
The load terminals are still connected to the battery, but the difference is that if the solar regulator sees that the battery is going too far down and there is not enough sun to bring it back up it will disconnect the "load" to save the batteries.
I don't use the load terminals for anything, to answer your question.
Martin
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Really it depends where your solar regulator is located whether there is any benefit to using the load terminals.
If it's near a 12 volt socket it would be pointless.
Mine is located in the garage so I feed a 12 volt socket for a cool box in there and it is switched from the bedroom above so it can be turned off at bed time so not to disturb sleep
funflair
19,303
30,068
Guisborough
MORELO palace
since 2012
And if that 12volt cool box was depleting the batteries to a dangerous level the requlator would cut the supply itself to save any damage to the batteries.
Not with your battery bank I know Andy(y)
Martin
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
Am I to assume from @Techno and @funflair response...
The "load" terminals just give you the option of a 12v feed from regulator - via your battery bank - with a "built-in" facility to turn off whatever is connected if batteries depleat to x voltage?..
Or is it just a regulated 12v supply direct from panel when sun shines that will turn off and feed Batteries as a priority?...
John T
funflair
19,303
30,068
Guisborough
MORELO palace
since 2012
@Fletton I am sure that it is as per your option 1 fed from battery bank with the automatic battery protection cut out.
Martin
Feb 16, 2013
19,696
51,876
uttoxeter
ambulance conversion
50 years
to these terminals.
Can't believe you have just posted that, we have exactly the same arrangement
funflair
19,303
30,068
Guisborough
MORELO palace
since 2012
The other use for the solar load output can be to power something even when your van 12volts have been shut down, or shuts itself down as British vans seem to do when you turn on the ignition.
Martin
Feb 16, 2013
19,696
51,876
uttoxeter
50 years
Martin
As does our arrangement
Fletton
1,531
2,501
Lincolnshire, UK
Martin
If that's the case... @funflair ... That's handy to know :) (y)
So ( without looking ) I should expect to see a feed from solar panel inbound to unit...
A solar "charge" feed to "whatever" - outbound...
And a live 12v feed in bound - from wherever - or perhaps direct from batteries?..to serve load terminals.. ?
funflair
19,303
30,068
Guisborough
MORELO palace
since 2012
The solar regulator feeds the batteries and then uses the same cables to feed the "load" terminals at the regulator with the cut out inside the regulator.
Martin
Techno
Jul 28, 2010
15,475
20,756
May 2010
Techno
Jul 28, 2010
15,475
20,756
May 2010
Relay so I can isolate with a small switch
In the bedroom above
rupert
Nov 23, 2014
198
199
c class
caravaning on and off 10 years
anybody know at what voltage the "load" cutout trips ??
rupert
Nov 23, 2014
198
199
c class
my controller is the one @Techno recommended 200w
Techno
Jul 28, 2010
15,475
20,756
May 2010
I think it alarms at 10.5 volts and disconnects at 10 so I would not rely on it as being helpful
rupert
Nov 23, 2014
198
199
c class
thanks for the info andy. but wouldn't want my batteries to get that low anyway so i guess i'll leave it alone
Baggers53
Baggers53
187
221
Stafford
On a nice sunny day like today all my batteries are fully charged.....
so the "free" lecky from the solar panel is charging 1x iphone and 1x ipad,
not going via the batteries so no discharge/charge cycle....
