Solar Output Controller....What do you connect to yours?
Discussion in 'Solar Power' started by Baggers53, Aug 6, 2016.
  1. Baggers53
    Baggers53 Funster
    Dec 30, 2013
    184
    220
    Stafford
    From most Solar Panel controllers there are two sets of output terminals.
    One for the leisure battery, and one for an additional load....What do you connect
    to these terminals.
    I have a device that has 3 car cigarette charger sockets and a USB port charger.
    So as we drive along or parked up on site a number of different devices can be
    charged from "free" solar power.
    • Like Like x 1
  2. JJ
    JJ Funster
    May 1, 2008
    14,784
    26,460
    My batteries...
    JJ :cool:
  3. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,775
    11,980
    Plympton, Devon
    I dont use them, all the power goes to the batteries and chargers etc are taken off them. I don't think the power from the load terminals is any more "free" than the power going to and from the batteries and the battery voltage will be a more reliable source - it will still be there in tunnels! :)
    • Like Like x 1
  4. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,152
    5,411
    Guisborough
    The load terminals are still connected to the battery, but the difference is that if the solar regulator sees that the battery is going too far down and there is not enough sun to bring it back up it will disconnect the "load" to save the batteries.
    I don't use the load terminals for anything, to answer your question.
    Martin
  5. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,140
    15,091
    Leeds the one up North
    Really it depends where your solar regulator is located whether there is any benefit to using the load terminals.
    If it's near a 12 volt socket it would be pointless.
    Mine is located in the garage so I feed a 12 volt socket for a cool box in there and it is switched from the bedroom above so it can be turned off at bed time so not to disturb sleep
    • Like Like x 1
  6. funflair
    Dec 11, 2013
    5,152
    5,411
    Guisborough
    And if that 12volt cool box was depleting the batteries to a dangerous level the requlator would cut the supply itself to save any damage to the batteries.
    Not with your battery bank I know Andy(y)
    Martin
    • Like Like x 1
  7. Fletton
    Fletton Funster
    Oct 19, 2014
    671
    2,635
    Nth East Lincs
    Am I to assume from @Techno and @funflair response...
    The "load" terminals just give you the option of a 12v feed from regulator - via your battery bank - with a "built-in" facility to turn off whatever is connected if batteries depleat to x voltage?..
    Or is it just a regulated 12v supply direct from panel when sun shines that will turn off and feed Batteries as a priority?...
    John T
  8. funflair
    Dec 11, 2013
    5,152
    5,411
    Guisborough
    @Fletton I am sure that it is as per your option 1 fed from battery bank with the automatic battery protection cut out.
    Martin
  9. chaser
    chaser Funster
    Feb 16, 2013
    7,507
    8,480
    uttoxeter
    Can't believe you have just posted that, we have exactly the same arrangement
    • Like Like x 1
  10. funflair
    Dec 11, 2013
    5,152
    5,411
    Guisborough
    The other use for the solar load output can be to power something even when your van 12volts have been shut down, or shuts itself down as British vans seem to do when you turn on the ignition.
    Martin
  11. chaser
    chaser Funster
    Feb 16, 2013
    7,507
    8,480
    uttoxeter
    As does our arrangement
  12. Fletton
    Fletton Funster
    Oct 19, 2014
    671
    2,635
    Nth East Lincs
    If that's the case... @funflair ... That's handy to know :) (y)
    So ( without looking ) I should expect to see a feed from solar panel inbound to unit...
    A solar "charge" feed to "whatever" - outbound...
    And a live 12v feed in bound - from wherever - or perhaps direct from batteries?..to serve load terminals.. ?
  13. funflair
    Dec 11, 2013
    5,152
    5,411
    Guisborough
    The solar regulator feeds the batteries and then uses the same cables to feed the "load" terminals at the regulator with the cut out inside the regulator.
    Martin
  14. Techno
    Jul 28, 2010
    14,140
    15,091
    [​IMG]
    • Like Like x 1
  15. Techno
    Jul 28, 2010
    14,140
    15,091
    Relay so I can isolate with a small switch
    [​IMG]
    In the bedroom above
    [​IMG]
  16. Fletton
    Fletton Funster
    Oct 19, 2014
    671
    2,635
    Nth East Lincs
    @Techno
    Ffs.... :roflmto: Very jealous ..... :envy: :smiley:
  17. Jonned
    Jonned Funster
    May 6, 2015
    33
    37
    Teesside
    Very impressed, very professional installation.
  18. rupert
    rupert Funster
    Nov 23, 2014
    118
    115
    leeds
    anybody know at what voltage the "load" cutout trips ??
  19. Techno
    Jul 28, 2010
    14,140
    15,091
    You would have to consult the instructions for each regulator
    • Like Like x 1
  20. funflair
    Dec 11, 2013
    5,152
    5,411
    Guisborough
    No
    Might depend on the controller.
    Martin
