Solar intallation finished.
Discussion in 'Motorhome Chat' started by Bushtrekker, Jun 30, 2012.
  1. Bushtrekker
    Bushtrekker Read Only Funster
    Jan 4, 2012
    253
    120
    Cannock, Staffs
    All connected and apparently working, although with no indication of what's going in it's hard to tell without running everything to see if it's charging with the engine off. Now all I need to sort out a solar powered engine, rainwater collection and composting toilet and I can stay out for months:BigGrin:
    • Like it Like it x 1
  2. Theonlysue
    Theonlysue Funster Life Member
    Sep 14, 2009
    3,128
    2,963
    Essex
    solar
    hi i have just had solar fitted to a hymer and if you use the correct regulator the panel above the door should tell you how much is going into your batteries. it also charges the engine battery when leisure is full
  3. andyman
    andyman Funster
    Sep 23, 2007
    1,164
    520
    Leicestershire
    Always satisfying to do a job yourself, and you it is done right.
    Plus you have saved a few quid.
  4. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,680
    7,934
    Quick test...
    On the regulator, use a multimeter on the feed coming from the dish..
    You should have 20v dc plus. so you will know panel is working.
    On the output side of the regulator to the battery, if it's charging then look for high 12v or even 13v dc that showns the regulator is charging the battery..
    Bon Voyage..
    I'll wave as we fly over on Tuesday... :thumb:
